Odd Issue With Pod Farm 1 (line6 Ux2)
11 replies to this topic
#1 Ablakk
Ablakk
  • 11 posts
  • Registered Products:1
Posted 21 July 2013 - 05:21 AM
Hi All,
I have noticed an odd issue with my POD Farm 1. In certain cases it doesn't work properly - I get just unprocessed sound for some amps/cabs (I own licence for them, so it doesn't seem to be licensing issue),
I run POD Ram and go to my preset. And either I hear unproicessed, clean guitar sound or I get very week processing, like Drive/Presence would be barely set. I usually have issues with Guitar Amps such as Line 6 Bottom, Deity's Son, Deity Lead, Cali Diamond Plate, plus some others I don't remember now.
When I get this issue I have to switch between different amps, presets, and so on, and finally, after several attempts I get my sound back.
I only have issues with mentioned amps. Others, like Line 6 Insane always work fine. Also, my UX2 sounds fine as sound card - I don;t have any issues, corrupted sound. Nothing like that.
I have reinstalled drivers, but the issue is still the same... I'm on Windows 7 64-bit.
Have anybody experienced similar issue? This is quite odd, and annoying on the same side, especially when I am in the middle of recording something. I put some guitars on, then try to get back to it next day... and I have to fight with POD Farm to get my sound back.
BTW, when I try to use the same preset on GearBox I get info that DSP can't load the sound. Unknown error.
Thank you in advance for any help!
#2 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 21 July 2013 - 05:16 PM
USB issue perhaps?  Try a different USB port or a different USB cable.
#3 Ablakk
Ablakk
  • 11 posts
Posted 23 July 2013 - 03:42 AM
@BigChas52 - thanks! Unfortunately, this did not helped... Still the same issue.
I have checked it under Lincense Manager and all is OK.
#4 Ablakk
Ablakk
  • 11 posts
Posted 24 July 2013 - 04:44 AM
OK, it never showed before but today.
When I opened GeaBox first, rather than using POD Farm, I got this error :
Reason: Code 8000740C Model definition decryption failed.
It has some code, so maybe it can tell somebody what it is related to and what would be the fix for it...
Thanks!
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 29 July 2013 - 06:33 AM
So you purchased a Metal Shop Model Pack License?
It does not come standard with the UX.
#6 Ablakk
Ablakk
  • 11 posts
Posted 30 July 2013 - 05:22 AM
Yes, I have purchased it as Triple Pack Offer, back in 2009. It properly shows up in License Manager.
It works randomly - sometimes it works right after I open PodFarm. Sometimes I need to open and close Pod Farm several times and then it would work. And so on. It's quite odd, as it is not consistent. And, as I mentioned at first post, I have reinstalled all drivers as per instructions posted here and there on this forum. Cable and USB port were changed, too.
#7 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 30 July 2013 - 10:24 AM
Just to clarify.
If you run Monkey you have green ticks?
License Manager shows the Pack Authorized for the UX?
Do you by chance also have POD Farm 2 installed?
It can sometimes trip up the license manager, even if you have a license for both.
Have you tried completely uninstalling POD Farm and using a fresh download outside of Monkey?
Is there another computer you can try this on?
#8 Ablakk
Ablakk
  • 11 posts
Posted 31 July 2013 - 11:44 PM
Yes, Monkey shows all green ticks. License manager shows these as authorized packs for my UX2.
I don't have POD 2 installed.
I will try to use it on another computer when I will go to my vacation house this summer.
Anyway, looks like I found some logic - it worked twice already, so maybe this is a workaround. When I open my PC and don't get any sound at these packs, I close POD Farm, run Monkey and then License Manager. Close them and run POD again - all sounds are fine... I wonder why I haven't thought about it earlier.
I will test it for another few days and if it will always work, we would have some workaround for people who have the same issue as me.
Still, I will try on other computer and will try uninstalling POD and installing it again, outside of Monkey.
Thanks for help, so far!
#9 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 01 August 2013 - 05:09 AM
Hopefully your work around won't suck up your 10 lifetime authorizations. It can be reset by Line6 by calling or submitting a support ticket.
I would definitely submit a ticket now if you see the work around is counting against your 10.
#10 Ablakk
Ablakk
  • 11 posts
Posted 02 August 2013 - 02:41 AM
Hm... is there any place to see number of authorizations? On my account I see this info:
You currently are using 1 out of 4 active devices.
You currently are using 1 out of 10 lifetime devices.
But I am not sure if this is info I would need.
On the other hand - I am opening the License Manager and closing it, without doing anything there. So, I am not deathorizing/authorizing. At least not intentionally...
#11 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 02 August 2013 - 07:54 AM
That is the info I was refering to.
#12 Travisjlee
Travisjlee
  • 1 posts
Posted 10 August 2013 - 02:27 PM
Sometimes when I select a sound in Pod farm it won't process like you talked about. When I select Dual tone and 'create empty tone' all of the sudden the sound starts processing. Maybe this will help you, too? It's a good piece of equipment but the interface is pretty terrible. If only it were as easy as plug and play, eh?
