jmp22684 Posted October 6, 2015 Share Posted October 6, 2015 Hello, Did a little searching around, perhaps not using the correct search terms so if this has been covered (most likely) and you know where please point me in the right direction: I have HD500x and two DT50 112's. What I want, switch between a distorted amp and a clean amp in the same patch.... What I am doing now (from a forum I read some time ago about this topic which I can't seem to find again): I put a volume pedal in front of each amp turned all the way down and toggle them on or off (both set to the same switch) for my clean and distorted amp. For the most part I have most of my patches set up to send the clean and dirtry through both amps (sorta mono, but I do do some stereo stuff). I was wondering if there was a way to do this in the same patch with out needing the two volume pedals and keep both DT50's on channel A? Basically I want to just shut off the amp in the patch with out the DT50 switching to channel B where I lose all control of that amp. Quote Link to comment Share on other sites More sharing options...
