Pod Farm 1 Not Compatible With Osx Mountain Lion
Best Answer Mm1066 , 22 July 2013 - 07:06 AM
Edit: Fixed my problem by uninstalling Pod Farm and reinstalling using the terminal method  :D
Go to the full post
6 replies to this topic
#1 Mm1066
Mm1066
  • 14 posts
  • Registered Products:2
Posted 21 July 2013 - 11:37 AM
I recently upgraded to Mountain Lion in order to get Logic Pro X, but as soon as I opened my old project files which used POD Farm 1, I am unable to use POD Farm. I find this frustrating as I need it for my bands EP. I refuse to believe that there isn't a way to get the original POD Farm working with new OSX, and I don't want to just buy the new software as the original software came with my POD X3 as it isn't very fair to me to have to spend more money for something I should already have.
Cheers,
  • 1
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 21 July 2013 - 11:56 AM
logic x requires 64 bit plugins... which means you will need to upgrade to 2.x
which you do not "already have" (64 bit plugins are one of the features that you get in the upgrade)
i know that pod farm 1 itself will work on mountain lion, you could try some other 32bit daws
apparently there are some 3rd party bridges out there that might help...
i got the info here: https://discussions....tart=0&tstart=0
but to be clear... apple is the problem here... the plugin will work on your OS, just not with logic x
#3 Mm1066
Mm1066
  • 14 posts
Posted 21 July 2013 - 04:19 PM
That's the thing, it doesn't work when I open up my OLD project files using Logic 9, just says "Plugin not available". After more research, I should still be able to use the demo version of PF2 with my expansion packs, but lo and behold, they aren't listed.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 21 July 2013 - 05:01 PM
wrong... you can't use expansion packs with the demo....
i'm not sure if logic x changes the underlying 32/64bit bridge for the plugins...
are you sure that logic 9 is running in 32bit mode?
(right click/get info)
#5 Mm1066
Mm1066
  • 14 posts
Posted 21 July 2013 - 05:14 PM
Yep I'm sure. The upgrade to lion also screwed with my drum replacer, which now doesn't work in either Logic Pro 9 or X :(
#6 Mm1066
Mm1066
  • 14 posts
Posted 22 July 2013 - 07:06 AM   Best Answer
#7 stevenmackod
stevenmackod
  • 2 posts
Posted 23 September 2013 - 12:33 AM
How!?
Please explain this magic trick!
Thanx!
