Ux2 Clip Lights When Playing In Pod Farm?
clip lights
7 replies to this topic
#1 jmarzjunior
jmarzjunior
  • 33 posts
Posted 28 April 2013 - 04:38 AM
Hi my clip lights go off on the ux2 while using pod farm. Evry time i use a high gain amp and set the volume over 70-80 % the lights go off. Is this normal or is there a way to solve this?
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
  • Registered Products:6
Posted 28 April 2013 - 04:37 PM
Try keeping the volume of the amp model to 2 o'clock or less for starters.
What are you monitoring with?
#3 jmarzjunior
jmarzjunior
  • 33 posts
Posted 29 April 2013 - 07:04 AM
I am monitoring with 2 krk rokit 6 aktive studio monitors. Is there anyway to make the ux2 louder to get more sound out of it? And one more question which sample rate should i run ux2 with, the standard is 16bit 44100 hz and you can go up to 24bit 48000 hz but on the line6 website it says Up to 24-bit/96 kHz recording this makes me little confused? Thanks
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 29 April 2013 - 07:23 AM
I typically have the volume on the monitors set relatively high and use the Master volume of the UX.
I usually use 48KHz  24-bit depth.
The 96Khz is with a sample rate conversion and would be a function of your DAW.
#5 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 29 April 2013 - 07:24 AM
Always turn you monitors On Last and Off First to avoid loud pops.
#6 jmarzjunior
jmarzjunior
  • 33 posts
Posted 29 April 2013 - 12:23 PM
Ok thanks for the support. I just have on last question. When i go into my line6 device settings of the UX2 it says under ASIO Settings  "default buffer size=512" and "default bit depth=16 bit"
And under "ToneDirect and USB Auidio streaming buffer size" its between Extra small and medium. This was how it was when i sat it up. But should i change it?? Whats yours set to?
#7 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7336 posts
Posted 30 April 2013 - 05:10 AM
For ASIO settings I usually have it set to 256 @ 24 bit depth.
For Tone Direct I am usually 1 notch form the smallest.
But you may need different settings depending on your computers configuration/performance.
#8 jmarzjunior
jmarzjunior
  • 33 posts
Posted 30 April 2013 - 06:52 AM
Ok thanks man.
My PC is 3GHz Dual core, 4,00 GB RAM and  Windows Home premium 7 with 64 bit operating system.
