Pod Hd300 Not Recognized, Installs As Unknown Device
pod hd300 unknown device trouble
Best Answer mus1prod , 02 July 2014 - 03:49 PM
If different usb port/different machine doesn't work, and factory restore or flash update doesn't work, try this:
Just do a midi dump from the pedal board itself. You don't need any midi software open on your computer, just make sure your computer is on and the pod hd300 is turned on and plugged into a usb port on your computer. Follow the instructions, that are in the manual, on how to do a midi dump -"ALL". You may need to power-cycle the pod and reboot your computer afterwards, but I've found that this does the trick every time.
Why this works: Honestly, since I don't work for Line 6, or have the schematics or any design information on the product I can't be 100% sure. My best guess would be that since the pods connect to, and exchange data with, the computer via midi-over-usb, there is a voltage-high(or low) situation with the eeprom. Kind of like when old analog telephones would act like they were busy when they weren't. There is the "on-hook" voltage(3v I think) that drops when you pick up the receiver. That change in voltage is the signal to the phone company's switch that signals that the phone is in use. When you hang up the phone, the voltage goes back up. If the voltage gets stuck low, then it looks like the phone is always busy. The only way to fix that was to disconnect the exterior test jack or incoming lines, temporarily, to reset the voltage. Doing a midi dump on the pod hd300 acts much the same as disconnecting and reconnecting the exterior phone lines.
Give it a try. If this works for you, let Line 6 know. And if you're the Line 6 moderator reading this, and it works as a consistent solution, let your bosses know. I could use a change in jobs.  ;-)
Go to the full post
56 replies to this topic
#41 rudirudirudi
rudirudirudi
  • 6 posts
Posted 02 August 2016 - 10:27 PM
greets.
Im rudi from Indonesia. pardon my english.
im having this problem too after upgraded the firmware, my pod just go silent and undetect from my PC. man its suck!!
the mp3 jack still working but theres no out put from the guitar in.
do i have to install the driver before doing midi dump ?
#42 mus1prod
mus1prod
  • 15 posts
  • Registered Products:1
Posted 03 August 2016 - 09:47 AM
rudirudirudi,
                       It reads like you have a very different problem. Is it just that your computer won't recognize the POD, or is there absolutely no sound coming out when you play your guitar through it? Does the LED panel light up when it's on?
#43 rudirudirudi
rudirudirudi
  • 6 posts
Posted 03 August 2016 - 04:44 PM
thank you for your reply, sir.
after upgrading the firmware to 2.01 theres no output through my guitar and my pod is unrecognized for the PC
but the mp3 output is working fine though. why the mp3 is o.k but theres no output from my guitar?
the LED, display, button is fine. but my pod is just go silent.
i have installed the driver but the status is unknown.
i try to update software from device manager, direct it to the driver folder, still unable to install so i can not do anything with the pod.
if the driver is recognize, i will be able to downgrade the firmware. i think theres a bug from the upgrade.
help me mate, please.
#44 BillBee
BillBee
    Guru
  • PipPipPipPipPip
  • 2531 posts
  • LocationMichigan
  • Registered Products:8
Posted 04 August 2016 - 02:16 AM
Did you re-calibrate the expression pedal?
Smell the glove.
#45 mus1prod
mus1prod
  • 15 posts
Posted 04 August 2016 - 09:20 AM
Ok, when you say that there "isn't any output from the guitar" do you mean that it just isn't playing out through the computer, or there is no guitar output through the XLR, phono, or headphone jacks?
If it's JUST not playing out through the computer, then I would try the following: 1)try a different, known-good usb cable; 2)depending on the version of Windows that you are running there are steps for uninstalling and reinstalling all usb ports through device manager, rebooting and letting Windows reinstall them, THEN reinstalling POD; 3)and of course restoring the POD to factory defaults.
If you aren't hearing the guitar out of ANY of the outputs, AND you've tried more than one guitar/or you've tried one guitar that plays through other amps, but not the POD, AND you've tried different patch cables, AND you have scrolled the the POD's onboard menu and made sure that you selected the correct output, there are two possibilities that come to mind:
1)Your upgrade to the firmware was unsuccessful, try to restore to factory defaults; 2) You bricked the ADAC and/or amplifier circuitry, which would account for anything plugged into the mp3 jack to be heard, but not the guitar input.
#46 sonoio666
sonoio666
  • 5 posts
Posted 04 August 2016 - 10:13 AM
Hi, I have a problem and I don't know how to manage it. I have a Pod HD300 and I'm trying to connect it to a mac (el capitan). I downloaded the latest version of Monkey and the latest Pod Edit, but I don't know how to make the drivers work. The download process seems to going great but, after the computer Reboot, Monkey keeps on saying that the drivers aren't installed. The pod hd 300 still not connected. I tried the midi dump process but it doesn't worked :(
thank you very much
#47 mus1prod
mus1prod
  • 15 posts
Posted 04 August 2016 - 01:33 PM
sonoio666,
The Line 6 usb drivers are NOT compatible with Mac OS 10.11 El Capitan.
Your options are either: go back to previous version of os all-together; or place the older version of the os and el capitan on seperate partitions.
#48 sonoio666
sonoio666
  • 5 posts
Posted 04 August 2016 - 01:38 PM
Is there a way to make it work?
However I had Yosemite and i had the same problem, i switch to el capitan to see if something would change, maybe I made another mistake...
thank you
#49 rudirudirudi
rudirudirudi
  • 6 posts
Posted 04 August 2016 - 10:38 PM
thank you for the reply.
theres no output from guitar to XLR, phono, or the headphone jack and it unrecognized by the PC.
i tried to restore to factory defaults, try another USB cable, but still theres no output.
is there a way to make it recognized for the PC ? so i can downgrade it.
#50 sonoio666
sonoio666
  • 5 posts
Posted 05 August 2016 - 06:57 AM
sonoio666,
Thank you but the 7.5.7 drivers description says: "this is a Free update to our audio/midi driver for Mac wich brings compatibility (...) when used in conjunction with mac os x el capitan".
So i think this isn't the problem (I had the same problem with yosemite, before the upgrade).
#51 mus1prod
mus1prod
  • 15 posts
Posted 05 August 2016 - 10:18 AM
rurdirudirudi,
I hate to say this, but it really does sound like the unit is "bricked"(dead).  You say that you get audio out from plugging into the mp3 jack, but are not getting ANY guitar out of ANY of the outputs; and it will not connect to the computer. That leads me to believe that the main board is dead. The mp3 input goes, basically, through a power amp circuit( I think) straight to output. There is no separate channel amplification, or other circuitry involved. Whereas, the guitar goes from input -> analog-to-digital converter -> preamp -> power amp -> digital-to-analog converter. That is where I believe your issue to be.
Good Luck,
S
#52 mus1prod
mus1prod
  • 15 posts
Posted 05 August 2016 - 10:21 AM
Have you ever had the POD HD300 connected and working with a Mac, at any point; or have you always had this issue?
#53 rudirudirudi
rudirudirudi
  • 6 posts
Posted 05 August 2016 - 11:35 AM
when im plugin my guitar and try to tune it through POD, theres no input from my guitar what so ever. and it makes me more frustrated. :(
if the main board is dead, i just wonder why the LED, display, and button is working fine ?
yes, the only problem are no guitar input / output and unknown by the PC.
and sorry for to much asking, mate.
i just wonder how much it cost to repair the mainboard? or is it just as expensive as buying a new POD HD ? :(
#54 sonoio666
sonoio666
  • 5 posts
Posted 05 August 2016 - 02:28 PM
thank you for the reply mus1prod.
No, I always had this issue. I tried with 2 two different Mac with Yosemite, El Capitan and Mountain Lions; I tried also with a PC with Windows 7, and it said "device unknow" when I connected the pod after the drivers installation.
Beside this issue, the Pod has no problems.
#55 mus1prod
mus1prod
  • 15 posts
Posted 11 August 2016 - 08:40 AM
It's possible that just the input jack is damaged, unsoldered from the board, something. As for why the display and buttons would light up, I wrote that in my last response.
I wish that I could help you more, but at this point, without having the POD in front of me, my troubleshooting skills are at an end. However, what I can suggest, is that you look in the forums for someone who has had the same problem as yours. This thread was about not being able to get FUNCTIONING POD HD300 to properly install on WINDOWS machines, not about PODS with no guitar output.  I would also suggest asking those, with the SAME issue as you, where they purchased their PODs from. I have noticed an unusual amount of people with damaged PODs that were purchased in Asia & Australia.
Good Luck.
#56 rudirudirudi
rudirudirudi
  • 6 posts
Posted 11 August 2016 - 04:36 PM
mus1prod
alright, mate. thank you very much.
i think im gonna send it to the service center. hope it is not cost a fortune :D
#57 yonhni
yonhni
  • 1 posts
Posted 24 October 2016 - 11:59 PM
Hello!! I have the same problem, it may be a hardware problem pod, trying different solutions but I realized that my antivirus closing recognized the pod USB port and installing the driver. my antivirus is malwarebytes anti-malware. Now the monkey pod x3 live recognizes him.
Also tagged with one or more of these keywords: pod, hd300, unknown, device, trouble
