M9 – Using Second Expression Pedal For Switching Between Scenes
m9 expression pedal scenes two second switch
5 replies to this topic
#1 RaphaBass
RaphaBass
  • 6 posts
  • Registered Products:1
Posted 25 July 2013 - 09:19 AM
I'm new to this, just bought the M9.
Did anyone ever try to use two expression pedals on the M9, each for different purposes/functions?
I'd like to know if it's possible to assign expression settings (like wah, volume or pitch) to expression pedal one and switch between scenes with pedal two.
Meaning I want to be able to change scenes on the fly and still have expression capabilities assigned to each effect/scene.
If that's not possible, what are the two expression inputs for?
What do you use the two expression pedals for?
Thanks for shedding some light here.
Rapha
- - Fender Jaguar (Matz customized with two Haller pickups and tremolo)
- Boss GEB-7
- Line6 M9
- MXR M87
- - TC RH 450
- - GK Neo 215
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9215 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 25 July 2013 - 10:16 AM
You can't use the expression pedals to change scenes. They're there to control whatever parameters you want to control in the effects. Almost every parameter can be assigned to an expression pedal, so how you set them up just depends on what you want to do. You can also control the parameters associated with the looper. As to why there's two, I'd say it's just to give more flexibility.
The settings for the expression pedals are saved on a scene per scene basis (except for the looper), so if want the pedals to control certain things in certain scenes you have to save the scene with those settings (assuming you're using manual save mode; in autosave mode, they will be saved with the scene as you set them up).
  • 1
#3 RaphaBass
RaphaBass
  • 6 posts
Posted 26 July 2013 - 08:33 PM
Thanks, Guru!
I dig the scenes, parameters and expression settings so far.
I was just hoping though there was a quicker way to switch forth and back between scenes, on the fly.
Too bad there isn't but hey, maybe I'll get used to the double plus single stomp for switching scenes.
You're saying expression pedal 2 can be assigned to different parameters for each FX, independent from expression pedal 1?
Let's take a distortion FX as an example: so I could dial in the amount of distortion with the first expression pedal and control treble settings with the second one? Dizzy!
Thanks!
Ra
Since you seem to be pretty familiar with the device, is there a way to save/store loops (similar to the Boss Rc's)?
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9215 posts
Posted 27 July 2013 - 08:34 AM
Well, I guess that is one limitation. You can't have different parameters in the same effect controlled by different expression pedals. But you can have different effects within the same scene controlled by different expression pedals. In the POD HD500, the expression control is similar to the M-series, but you actually could control different parameters within the same effect with different pedals.
No, there isn't. The looper really is meant for only on-the-fly looping. You can't load pre-recorded loops or export loops that you've made.
#5 RaphaBass
RaphaBass
  • 6 posts
Posted 29 July 2013 - 05:38 AM
Again, thanks for your quick response.
If I get that right:
I can't even have one expression pedal assigned to tweak parameters on individual effects and use the other expression pedal to control the volume for scenes?
If that's the case I'm still not sure what the purpose of two effect slots/pedals is.
I was hoping I could significantly shrink the amount of pedals on my board but it looks like I'll still end up with a volume pedal, an EQ and a looper in addition to the M9.
#6 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9215 posts
Posted 29 July 2013 - 06:58 AM
Well, you could use the second expression pedal to control the volume effect in a scene, but if you use the volume effect, that eats up one of your slots in that scene. I would say that if you want to control volume, you're better off getting a dedicated volume pedal rather than a second expression pedal. They take up about the same amount of space on your board, anyway.
I don't currently have the M9. I have the M13, and I use both expression inputs. I like it because it gives me freedom to assign different parameters of different effect independently from each other. I often will assign the delay feedback (repeats) to the one so I can force a delay to go into self-oscillation very easily. I'll have the other pedal setup to control things associated with modulation. I like controlling the mix parameter of a tremolo, for example. It's nice for blending effects in slowly.
Also tagged with one or more of these keywords: m9, expression, pedal, scenes, two, second, switch
