Dt25 In The Studio?
8 replies to this topic
#1 grandinq
grandinq
    Iknowathingortwo
  • PipPip
  • 136 posts
  • Locationsoutheastern Mass
  • Registered Products:5
Posted 25 July 2013 - 11:26 AM
I love the sound of my DT25 + HD500 in a live setting. Best tone I have ever had with a band. Does anyone use it to record in a studio setting? I've tried an SM57 on it, but so far it hasn't captured that glorious sound.
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9212 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 25 July 2013 - 02:22 PM
I've not recorded in an actually studio, but I have recorded it with a mic before. I liked the results. I'm not a huge fan of the SM57, but it should give OK results. I usually use a Sennheiser E609 to mic my amps, but at home I've also had good results using an MXL ribbon mic I have.
#3 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16052 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 25 July 2013 - 02:49 PM
For studio recording, have you tried the HD500 itself (usb connection) with no DT25? Set the HD500 Output Mode to Studio, use the Full (not Pre) amp models, select your choice of mic/cab simulations and see if you like the results. It may not match the HD500/DT25 tone, but unless you can play that DT25 at loud volume while recording, and use a really good mic, the HD500 alone might be comparable or even preferable.
.... John Lennon
#4 grandinq
grandinq
    Iknowathingortwo
  • PipPip
  • 136 posts
Posted 25 July 2013 - 04:10 PM
I have a bank if direct sounds from the pod that I have tried for recording. It can get quite a nice sound, no doubt about that. The DT25 just has this special quality to it. For instance, I have a JCM800 patch I use with the DT25/pod. I can't get anything close to it with the pod alone.
#5 grandinq
grandinq
    Iknowathingortwo
  • PipPip
  • 136 posts
Posted 27 July 2013 - 01:08 PM
Update:  I tried out a Sennheiser e609 and things look promising.  If I get a chance I will post a sound clip.  So far I've just tried on my JCM800 patch, trying to keep the sound simple.  I really need to try this out at my friend's studio so I can sit in the control room with the POD and he can move the mic around in the other room.
#6 geppert
geppert
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationWest Coast, Canada
  • Registered Products:7
Posted 27 July 2013 - 01:43 PM
.............  I really need to try this out at my friend's studio so I can sit in the control room with the POD and he can move the mic around in the other room.
Sounds like (pun intended) you need ... "The Tone Tank" ....
#7 grandinq
grandinq
    Iknowathingortwo
  • PipPip
  • 136 posts
Posted 27 July 2013 - 06:27 PM
I love the look of the Tone Tank -- that would be handy to have!
Here is my sample miking the DT25 with my e609. Patch is a JCM800.  There is some eq added because I used a Weber attenuator and I needed to add some highs back in.
https://soundcloud.c...5-jcm800-e609-3
#8 sonic
sonic
  • 43 posts
  • LocationHaacht, Belgium
Posted 19 August 2013 - 07:19 AM
Love that sound ! I'm also a big fan of the e609.
Sammy
Sammy
Line6 DT25 head and cab, Line6 HD500, Line6 JTV 59.
Marshall JVM 410H, 1960 AX cab.
Gibson SG Standard.
Steinberger GM 4S (Newburgh).
#9 grandinq
grandinq
    Iknowathingortwo
  • PipPip
  • 136 posts
Posted 24 August 2013 - 11:26 AM
Update!  I was playing around with the e609 miking the DT25 again, this time with a patch based on the Brit 75 amp:
http://line6.com/cus...ne/tone/225648/
I recorded this in my bathroom in the basement, using a new song idea.  Here's an excerpt of how it sounded:
https://soundcloud.c...5-recorded-with
I'm pretty happy with the results so far.  I've been using Pod Farm, and this beats it in terms of sound, though Pod Farm is quite versatile and easier to set up.
