shredjsx Posted November 4, 2015 Share Posted November 4, 2015 I have the hd500x I noticed that the file type was different for hd500 patches Can I use them? Quote Link to comment Share on other sites More sharing options...
Dutchguitarist Posted November 4, 2015 Share Posted November 4, 2015 Yes you can use them, either just drag & drop the 500 patches in HD500X edit and you are fine or, as an alternative, there is a patch conversion program. See the pinned message at the top of this forum Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted November 4, 2015 Share Posted November 4, 2015 No need for converting them, unless you run into that one particular patch that doesn't work. Just a 'drag and drop' is fine. NOTE: All 500 patches should work on the 500x. Almost all 500x patches will work on the 500 There is a very slight DSP increase in the X, so it is possible that a few won't work. Should you run into one that gives a dsp error, you can open the patch in EDIT while in 'offline mode' to delete one fx block (I usually go with fx loop or volume pedal). As long as it is a DSP error and not a corrupted file, removing one block will make it work. 1 Quote Link to comment Share on other sites More sharing options...
shredjsx Posted November 4, 2015 Author Share Posted November 4, 2015 Cool, one of the guys on here created some awesome sounding synth and piano patches I want to try... Thanks you Quote Link to comment Share on other sites More sharing options...
