Pod Hd500x - Midi Madness... A Question.
7 replies to this topic
#1 Jasonbrianmerrill
Jasonbrianmerrill
    Iknowathingortwo
  • PipPip
  • 148 posts
  • Registered Products:1
Posted 25 July 2013 - 07:31 PM
Hello,
I was thrilled to hear that the Pod hd500x was also usable as a midi controller.
However, I have found the process absolutely time consuming and confusing.
I use reaper - in my midi devices in reaper, I see the Pod HD500x:
https://www.dropbox....25 23.30.01.png
notice that the pod hd500x is coming up as a midi device?!?!!
however, I have a midi cable connected to the firepod, my interface.
which one actually works? What is the step by step process? Can I set it in HD500X Edit? The manual is about as clear as mud on this one.
#2 Rewolf48
Rewolf48
    Power User
  • PipPipPipPip
  • 1217 posts
  • LocationUK
  • Registered Products:6
Posted 26 July 2013 - 12:01 PM
It doesn't work as a USB MIDI interface.
It is a MIDI device so that it talks to Edit, and it is a MIDI controller over the MIDI out, but you can't use it to communicate to other devices from a host computer
#3 SiCantwell
SiCantwell
  • 74 posts
Posted 26 July 2013 - 01:06 PM
It would be a nice upgrade if you could use a 500/500X to turn a guitar into a MIDI controller. I have some great iPad synth apps that would be fun to play with my guitar, but I don't want to spring for a MIDI pickup.
  • 1
#4 Jasonbrianmerrill
Jasonbrianmerrill
    Iknowathingortwo
  • PipPip
  • 148 posts
Posted 26 July 2013 - 01:16 PM
it DOES work as a midi device,  but not as a USB midi interface.
I would not use the USB at the same time as the midi, I think it confuses it.
I have it controlling pedals and wah in revalver right now.
  • 1
#5 scheater5
scheater5
  • 79 posts
Posted 28 July 2013 - 02:06 PM
@SiCantwell  That's not how midi works.  Midi pickups individually pick up each guitar string, allowing them to be processed separately.  Something extremely similar occurs in the Variax.  Midi controllers are another beast altogether - that's using midi signals to trigger events, such as changing a patch on an effects unit.  It's even theoretically possible to use the HD500 to control a rackmount synth and have the switches act as keys through midi signals.
BUT, there is no midi signal coming from your guitar without a midi pickup, therefore the HD500 cannot possibly "turn your guitar into a midi controller."
#6 ShivamBhatia012
ShivamBhatia012
  • 2 posts
Posted 10 June 2016 - 08:09 AM
hey ..attention ..please this is for line 6 pod hd 500x .....since boss has now released its new update for gt 100 that converts guitar into a midi device .. i am feeling inferior with my line 6 product which i recently brought (pod hd500x) ... please i expect quality resolution and hope u will keep up the best multi effect processor :D ;) pls make a update for pod hd 500x :(
  • -1
#7 cruisinon2
cruisinon2
    Uber Guru
  • 5167 posts
  • Registered Products:5
Posted 10 June 2016 - 08:55 AM
Ugh.
#8 panaman
panaman
    Iknowathingortwo
  • PipPip
  • 131 posts
Posted 03 July 2016 - 01:14 AM
i really wish someone could write a step by step midi setup tut for the dummyest, not leaving out any of the most basic and obvious, still havent figured that out
like send the pedal midi to pc/daw, map or modulate it, then return it to pod to control a parameter, or can this be done?
the one vid on youtube dealing with midi on the pod is in portugese and about as helpful as the cc table in the manual
i can figure out things on the daw side, the pod remains a mystery
