Pod Hd 500 Looping
5 replies to this topic
#1 matronryan
matronryan
  • 1 posts
  • Registered Products:3
Posted 26 July 2013 - 01:24 AM
I normally use a RC 300 for looping as i have a lot of pre-recorded tracks. When I use the HD 500 I can't seem to clear the loop recorded without turning the unit off and on - I'm sure I'm missing something - any help would be great
Thanks
#2 smrybacki
smrybacki
    Gear Head
  • PipPipPip
  • 669 posts
  • LocationCarlisle, PA
Posted 26 July 2013 - 04:58 AM
Look here:
http://line6.com/support/thread/74597
From the advanced guide, page 8.3:
Note: If you press REC/OVERDUB while Loop playback is stopped, this will always record a new Loop, and any previously recording will be discarded.
And I use the RC30 for looping, and it is ever so much better in every way.  Not surprising since it is a dedicated looper and this is no knock on the HD500's built in looper mind you.  But anyone into "serious" looping will bust through 48 seconds in no time flat (pun intended).
However you play music using whatever gear you may choose that day-- the JOY of making it is the heart of it.
#3 gunpointmetal
gunpointmetal
    Power User
  • PipPipPipPip
  • 1100 posts
Posted 26 July 2013 - 05:27 AM
yeah, you can't undo to nothing...there is always a first loop on there until you power down....You can always hit Play/Stop to turn it off (twice if in overdub mode; once for "play" once for stop; once if just in Play mode.)
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9226 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 26 July 2013 - 05:31 AM
If you go into tuner mode, the stored loop will be erased. But really, it's hard for me to see why it's a big deal. The current is always overwritten as soon as you start recording a new one.
  • 1
#5 Angerplate
Angerplate
  • 1 posts
Posted 07 August 2013 - 11:09 AM
Hey Guys
My problem sound is not to be clear when I work on looper with my HD 500.How can I get real clear sound rthm & lead together.
Thanks
#6 spaceatl
spaceatl
    Uber Guru
  • Line 6 Expert
  • 5377 posts
  • Registered Products:6
Posted 07 August 2013 - 11:21 AM
Hey Guys
Thanks
If your patches are stereo, you can run into some weirdness with a post looper....the looper buffer is mono and your post tone is summed mono...so the playback is always a bit different in that regard depending on the patch...If your looper is set pre, well that's your problem...
