Can I Utilize A Usb 3 Cable For My Pod X3?
5 replies to this topic
#1 omonoiatis9
omonoiatis9
  • 49 posts
  • Registered Products:2
Posted 26 July 2013 - 04:50 AM
So I've been wondering. I heard that the USB 3 technology has 10 times faster transfer rates than USB 2. And I can't help but wonder, is it possible that if I buy a USB 3 cable (can it be hooked on the POD x3?), and then connect my POD with the PC on a USB 3 port, do I get even shorter latency? Or is this not possible at all?
My band recently released our demo album, which was recorded entirely through a POD x3. Guitars, bass and vocals. Check it out and tell us what you think. :)
 https://soundcloud.c...ursed-vanguards
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17812 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 26 July 2013 - 04:53 AM
the internal hardware of the X3 is only USB 2.0, so you will not get any benefit by plugging into a USB 3.0 port...
in fact i've seen reports that a USB 3.0 port can hurt performance.
#3 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 26 July 2013 - 05:05 AM
I only have one USB 3.0 device, and it has a different connector at the device end.  You might want to give it a try with a normal USB 2.0 cable.  Let us know if it works for you.
#4 omonoiatis9
omonoiatis9
  • 49 posts
Posted 26 July 2013 - 07:13 AM
Thank you guys. Hmm, what do you mean try with a normal USB 2.0 cable? You mean I should try plugging my POD x3 with a usb 2.0 cable onto the USB 3.0 port of my computer? TheRealZap said there aren't any benefits in doing this and there's even been opposite results so I'd rather not, if that's what you meant.
#5 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 26 July 2013 - 10:09 AM
Yes, use a USB 2.0 cable to plug in to a USB 3.0 port.
As Zap suggested, I would continue to use USB 2.0 ports if they are available, but you cant hurt anything by trying the USB 3.0 ports.  I'm just not sure that you will get satisfactory results.
With newer computers, USB 2.0 ports are becoming scarce real estate.  I have tried out different devices on my 3.0 ports to try to free up the 2.0's.  Sometimes they work fine, and sometimes they are dodgy.
#6 ebiggins
ebiggins
  • 1 posts
Posted 29 March 2016 - 11:41 AM
I can verify that plugging a 2.0 cable into a 3.0 usb port is a latency horror. I tested by using the Jamkazam software which measures your latency and my latency was almost twice that of the usb 2.0 port. As it is, even in the 2.0 port the Pod X3 has to much latency to use with Jamkazam.
