Can you use any of the mod effects like phaser, chorus, flanger with tap tempo?
HonestOpinion
Is there a way to use any of the mod effects like phaser, chorus, flanger with tap tempo? I set "Tempo Select"='Global' but my mod effects don't seem to follow it.
Many effects with "Rate" could have a parameter to indicate "Tap" or "Preset" which would determine if the "Rate" is to be set according to the tap tempo or the preset's "Rate" setting. That way all of the effects and delays could follow the tap tempo where desired. Is there a way to do this?
