Lynchworm12 Posted November 17, 2015 Share Posted November 17, 2015 Maybe this has been brought up before or is already possible. It sure would be cool if the expression pedal could be used as a whammy pedal. I saw one of the effects uses an effect from the digitech whammy pedal but is not really a standard whammy. Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted November 18, 2015 Share Posted November 18, 2015 You can do it just long press on the position parameter and select it as fx tweak and then select pedal for control, I was using it tonight Quote Link to comment Share on other sites More sharing options...
Lynchworm12 Posted December 2, 2015 Author Share Posted December 2, 2015 I took your advice and assigned that effect to the pedal. I didnt really like the sound too much. Seems like its more of a synth effect than a whammy. Is there a specific preset you could post to the cloud that I could check out? Quote Link to comment Share on other sites More sharing options...
Levlevit Posted January 13, 2018 Share Posted January 13, 2018 Maybe this has been brought up before or is already possible. It sure would be cool if the expression pedal could be used as a whammy pedal. I saw one of the effects uses an effect from the digitech whammy pedal but is not really a standard whammy. Quote Link to comment Share on other sites More sharing options...
