New Driver + El Capitan sudden reboots
madmax559
Line 6 Pod X3 Pro
Running the latest Line 6 Monkey & driver on OS X El Capitan 10.11.1
Pod X3 Pro connected via usb.
If you turn off the pod sometimes OS X will suddenly kernel panic & reboot
I've had this happen 4 or 5 times now & its somewhat intermittent but usually happens if i power off the pod
On an unrelated note
gearbox does not recognize this new drive "incompatible driver installed" ..it does however read in the patches, but editing does not work.
If anyone else is seeing sudden reboots please post here.
  • 4 weeks later...
  • 2 months later...
Crashed again 5 min ago.
Line6 Pod X3 Pro connected to iMac 27" mid 2010.
Input & Output via pod
Playing a track using amazing slow downer.
Jammed along on the guitar plugged into pod & stopped
Quit app slow downer and everything is still fine.
Reached over & hit the power switch on the pod x3 ....and .... the iMac instantly kernel panicked & i lost everything else i had open at the time.
This is 100% reproducible every single time & I can't believe others aren't impacted as well.
How did this escape QA ?
I'm digging around to see if i can locate a core file or any other dump
  • 9 months later...
