asdasd Posted December 2, 2015 Share Posted December 2, 2015 Hi there.I just buy a pair of krk rokits 5" and i didn't use them yet because i wanna be sure the connections i will going to do its ok.I have a Pod Hd 500 and the connection it will be: 1/4" out from the pod > to 1/4" of the krk directly. Its that ok?I have fear about breaking the krk's 'cause of the signal level or something like that, because non of this haven an indicator of the signal. Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 2, 2015 Share Posted December 2, 2015 Yes, that will be fine. For best results set the Output Mode in the HD500 to Studio/Direct and set the switch for the 1/4" outputs to Line (not amp). I would start by setting the KRK volume level to mid-range value (the 'notch' position if there is one). Set the HD500 master output level low and increase it until you get a good sound volume in the room. If you need more then increase the KRK levels. Quote Link to comment Share on other sites More sharing options...
asdasd Posted December 2, 2015 Author Share Posted December 2, 2015 Ok. i will try it. Thanks. Quote Link to comment Share on other sites More sharing options...
