Dt25 Firmware Update With Midi Ox?
8 replies to this topic
#1 Zodiaq77
Zodiaq77
  • 6 posts
  • Registered Products:1
Posted 29 July 2013 - 06:00 AM
Is there a way to update the dt25 firmware using midi ox? And if so does anyone know the procedure?
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 29 July 2013 - 06:28 AM
using one of these is MUCH easier: http://line6.com/sup...ted-dt-editors/
although midi-ox can be done... i've done it... was a pain... don't recall the procedure... just made and sent the midi code.
#3 Zodiaq77
Zodiaq77
  • 6 posts
Posted 29 July 2013 - 07:55 AM
I didn't mean changing the amps, but the actual firmware upgrade but thanks.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
you just need to use monkey for the firmware upgrade... no reason for midi-ox
#5 Ronco46
Ronco46
  • 14 posts
  • LocationBeja - Portugal
  • Registered Products:3
Posted 04 August 2013 - 10:02 AM
@TheRealZap,
So, you mean, with DT25 and POD HD500 connected via L6 Link and the POD connected to the computer via USB, I'll be able to upgrade DT25 Firmware, using Line 6 Monkey?
Don't I need DT25 connected to the computer via MIDI cables (since DT25 doesn't have a USB port)?
Thanks
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 04 August 2013 - 11:26 AM
you need to have a separate midi interface connected to the dt25, monkey will see it.
it will not work without a separate midi interface.
#7 Ronco46
Ronco46
  • 14 posts
Posted 16 August 2013 - 04:47 PM
I've done it already!
With Line 6 Monkey and M-Audio Uno (MIDI to USB cable), couldn't be easier :)
#8 notryt
notryt
  • 7 posts
Posted 03 August 2014 - 09:42 AM
need a link for the dt25 head firmware .. firmware does not seem to be available for this unit on the line 6 website.. just info on what the update does.. i find this strange...
email me a url to notqytryt@netzero.com    thanx
#9 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17813 posts
Posted 03 August 2014 - 09:53 AM
it's right here: http://line6.com/sof...a.html?rid=5396
went right to it via the downloads link at the upper right...
once you get to the noted the "get download" link is in the lower right of those notes...
blends with the color scheme a little...
