5jamjwji8 Posted December 13, 2015 Share Posted December 13, 2015 So when using the POD Pro HD X as my interface to record over USB. I have the ASIO driver selected in Reaper and it works just fine. But the record level is a bit low. Meaning I'm not getting enough volume into my tracks. How can I adjust this? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 13, 2015 Share Posted December 13, 2015 You need to increase the Send level from the Pod. Here's a snip from the Pod ProX manual describing how to do that: The Record Send appears as an available audio input/recording device within your audio software. Simply select this Send as the input for your audio track and you’ll be able to record your POD HD Pro X signal. The level of the signal fed to the Send is affected by your POD HD Pro X controls: Mixer block Volume A & B, Amp Model Drive & Volume, FX Model Gain controls, Volume Pedal, etc., (but not the Master Volume knob). For the best recording quality, watch the input meters provided in your software and adjust your level to be at least halfway up, but never “clipping.†Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 13, 2015 Share Posted December 13, 2015 I guess the manual is using generic terminology when it says "Record Send". It probably shouldn't be capitalized because the Daw doesn't see it as a 'send'; it sees it as an input (like Reaper sees Input 1 and Input 2). I think what the manual means is the the signals the Pod is sending over usb are seen in the DAW as signal source input options. In any case, the outgoing 'send' signal level needs to be increased in the Pod (and/or as you point out in the driver control panel), not as an incoming 'input' signal level in the DAW. Quote Link to comment Share on other sites More sharing options...
5jamjwji8 Posted December 13, 2015 Author Share Posted December 13, 2015 so that was it. just increase my preset volume and it works fine. thanks Quote Link to comment Share on other sites More sharing options...
