Thoughts On Pod Hd500x
22 replies to this topic
#21 BowedFrancis
BowedFrancis
  • 10 posts
Posted 28 February 2014 - 10:44 AM
The looper on the HD50 is a great tool for practicing solos over a backing chord sequence, and is also great for auditioning and tweaking tones to hear the changes in real-time without having to stop playing to tweak. It is not so good as a real-time looper in a performance/live situation.
Where do you think the looper falls short live? I've been using the DL4 in my live setup since it came out and I love it.  Is there a big difference?
#22 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 11098 posts
  • LocationOttawa, Ontario, Canada
Posted 28 February 2014 - 11:35 AM
Using the HD500 Looper in a live setting is cumbersome due to the number of footstomps required to engage/disengage the looper while switching patches for different tones.
For instance, a common situation is to lay down a chord sequence for the verse portion of a song to be used as a backing track when the lead solo, using a different preset, comes along, then segue smoothly back into playing a verse or bridge live. Laying down the original loop is no problem - you engage Looper mode, then use the footswitches to start and stop recording the loop. At that point you probably aren't at the point in the song for your lead solo so you stop the loop playback. Now when the solo comes along you need to almost simultaneously start the loop playback while also switching presets for the solo. Some fancy footwork is required to achieve that and maintain tempo. If you manage that successfully, you still have to disengage the loop playback when the solo ends and also switch presets back to the original - also while maintaining tempo.
Try it. It requires both careful planning to start/stop recording your loop at the 'right' instants (which may not be on the beat if you want to allow time for patch switching) and also some extremely fast and accurate footwork in the stomp sequences. I haven't been able to master it while keeping my playing tempo.
.... John Lennon
#23 BowedFrancis
BowedFrancis
  • 10 posts
Posted 28 February 2014 - 01:31 PM
Ah, I get what your saying. I use it in a different fashion and actually dump my loops down to other loopers to build multiple movements.  With bowed strings you can sneak in behind the beat without causing much of a fuss. I can see where your situation would require some acrobatics!
