Cynoxious Posted December 21, 2015 Share Posted December 21, 2015 All of a sudden no matter what I do. Restart PC, Check line 6 monkey (everything up to date), Check license manager, constantly reopen pod farm, disable and re enable the device, messed with the gain, toggle phantom power, or even replug-in every device, it will not pick up my at2035 microphone that I have been using for about 5-6 months now. The program has always seemed to be buggy but this is the most frustrating issue I've had where nothing I do seems to get the ux2 to pick up the microphone. I have no idea if this a podfarm issue or my mic decided it just wanted to stop working one random evening. Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted December 21, 2015 Share Posted December 21, 2015 You definitely need phantom power with the AT2035. Have you double checked the "Input" setting" in POD Farm to make sure it is pointing to the MIC port on the UX2 that you are using? Have you checked the MIC cable? Have you checked to make sure that the AT2035 is working properly by using it with another device? Have you checked the USB cable and tried a different USB port? Troubleshooting is the process of eliminating variables, one at a time. What troubleshooting steps have you taken? What have you been able to eliminate as being the possible source of the problem? Quote Link to comment Share on other sites More sharing options...
Cynoxious Posted December 21, 2015 Author Share Posted December 21, 2015 I ended up solving the problem and im kind of embarrassed about it. Just a bug I'm assuming caused a setting to change the input device. I had trouble shooted almost everything else and was about to even buy a new microphone. Quote Link to comment Share on other sites More sharing options...
