Clean Guitar Sound On Top Of Effected When Recording
3 replies to this topic
#1 dwightweeks
dwightweeks
  • 2 posts
  • Registered Products:1
Posted 30 July 2013 - 06:17 AM
When I record any guitars through Pod, I get a loud clean guitar sound simultaneous with whatever Pod sound I've chosen. But when I record through an existing channel with Pod off, I get the original pod sound without the clean on top. I've tried Monkey and restarting and all the usual crap. Any help out there?
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 30 July 2013 - 08:06 AM
Check out the POD Farm mixer view.
There are 4 sends. You can chose what to send to your DAW, Processed, Dry Input or Semi-Processed
Depending on if you have POD Farm 1 or 2 it may be named slightly different.
If you have the POD Farm plug-in a typical workflow is to capture wet and dry to different tracks simultaneous then add the plug-in to the dry track post processing.
#3 dwightweeks
dwightweeks
  • 2 posts
Posted 31 July 2013 - 05:31 AM
All I have is Tone A, Tone A (semi), Dry
I've tried all and nothing helps.
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 31 July 2013 - 07:20 AM
So I'm assuming this is POD Farm 2?
What DAW are you using?
