jpelzel Posted December 27, 2015 Share Posted December 27, 2015 As it says. Lately been getting more and more electrical noise through the mags. I figure it needs better shielding but with all that extra stuff in there I want to be sure that I don't mess something up. Any tips as to what to watch out for? Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted December 27, 2015 Share Posted December 27, 2015 Are you using a vdi or regular guitar cable? Always worth trying a different cable first Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted December 27, 2015 Share Posted December 27, 2015 Could be anything in the signal chain...might not be the guitar at all. But as stated above, start with the cables. They get twisted, stepped on, kicked around, etc, and are more likely to crap out than anything else. Quote Link to comment Share on other sites More sharing options...
jpelzel Posted December 27, 2015 Author Share Posted December 27, 2015 Both cable types, different equipment. The only variable that seems to have a positive effect is switching guitars so seems pretty well narrowed down to the instrument itself. Quote Link to comment Share on other sites More sharing options...
vmoncebaiz Posted December 31, 2015 Share Posted December 31, 2015 I haven't come across a variax with that issue yet, and if it's happened recently, I don't think the shielding would be the heart of the issue Is there any difference in the noise when you touch the strings or the pots? Sometimes a guitar's bridge ground wires loses its connection (maybe corrosion from sweat or just getting worked by the floyd). Check the wire that is soldered, or connected to the trem spring claw. If thats not the case, then shielding may help, it can't hurt, and its easy to do yourself. If you do it, just be mindful of anything that would touch the shielding and ground itself out. Grab some shrink wrap tubing (or electrical tape works too) and cover exposed wires or contacts that might touch your shielding. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 31, 2015 Share Posted December 31, 2015 Log a ticket in the Line 6 ticketing system in your account. Make sure your product is registered. Needs to be troubleshooted further by an authorized service tech. Quote Link to comment Share on other sites More sharing options...
jpelzel Posted January 1, 2016 Author Share Posted January 1, 2016 I haven't come across a variax with that issue yet, and if it's happened recently, I don't think the shielding would be the heart of the issue Is there any difference in the noise when you touch the strings or the pots? Sometimes a guitar's bridge ground wires loses its connection (maybe corrosion from sweat or just getting worked by the floyd). Check the wire that is soldered, or connected to the trem spring claw. If thats not the case, then shielding may help, it can't hurt, and its easy to do yourself. If you do it, just be mindful of anything that would touch the shielding and ground itself out. Grab some shrink wrap tubing (or electrical tape works too) and cover exposed wires or contacts that might touch your shielding. Touching the strings has no effect. It wasn't really all of a sudden, been kinda growing over time. I will probably go in and upgrade the shielding. Just wanted to be aware of ant gotchas. Log a ticket in the Line 6 ticketing system in your account. Make sure your product is registered. Needs to be troubleshooted further by an authorized service tech. Thanks for that. Maybe, butI was more in the mind to avoid such thing. I could send back to Sweetwater as well but just seems to be a PIA. Quote Link to comment Share on other sites More sharing options...
