Pod Studio Ux Very Low Input
11 replies to this topic
#1 CRXLunatic
CRXLunatic
  • 5 posts
Posted 29 April 2013 - 05:40 AM
Is it normal that the input of my guitars (active or passive PU's, all the same) is very low and never exceeds -30dB with normal playing? Or is my UX1 broken?
Currently I have to crank the amps to get some volume, which is extremely annoying when recording. It feels as if there a huge noisegate in front of the UX1. I have very little sustain, and tapping is almost impossible unkess you ram on the strings like a manic...
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
  • LocationClemmons, NC USA
  • Registered Products:17
Posted 29 April 2013 - 05:54 AM
it's normal , because the input signal is left dry and as input. this is to give you the overhead to use the amps and effects in pod farm later....
it's not typically fed to a guitar amp... usually to monitors/headphones or computer speakers.
#3 CRXLunatic
CRXLunatic
  • 5 posts
Posted 29 April 2013 - 06:09 AM
I use POD Farm (and Revalver, Overloud TH2, etc. all the same low input problem), and my output goes directly to my monitors. The amps I mentioned are amps in POD Farm.
I watched some movies on Youtube about POD farm, and (also with a UX1 or UX2) their input is much higher than mine.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
Posted 29 April 2013 - 06:11 AM
yeah, it should be loud if you're going through a plugin of any kind generally.
#5 CRXLunatic
CRXLunatic
  • 5 posts
Posted 29 April 2013 - 06:29 AM
So would that mean my UX1 isn't working properly?
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
Posted 29 April 2013 - 06:32 AM
might be your pc/mac i wouldnt say 100% hardware at this point.
#7 CRXLunatic
CRXLunatic
  • 5 posts
Posted 29 April 2013 - 06:36 AM
To rule out my PC I tried my notebook, and a virtual Windows 7 PV. They both got the same problem.
#8 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17756 posts
Posted 29 April 2013 - 06:40 AM
sounds like you've isolated it. is it under warranty or can you get an exchange?
#9 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7126 posts
  • Registered Products:6
Posted 29 April 2013 - 06:53 AM
Are you new the UX1?
Is this a "black faced" POD Studio?
If you run the newest version of Monkey do you have green ticks for drivers, firmware and POD Farm?
Maybe you're overlooking a minor detail.
Have you adjusted the faders in POD Farm's mixer view?
#10 CRXLunatic
CRXLunatic
  • 5 posts
Posted 29 April 2013 - 07:09 AM
Yes, it's only a few weeks old, so should be under warranty.
@Triryche
Yes, it's the black faced one.
I had some updates when I first connected the UX1, but no more after that.
I am the following driver level now:
Drivers: 4.2.5.4
USB Firmware: 1.01
Line 6 Monkey: 1.62
POD Farm 2: 2.55
I think the faders are fine, but if there's anything I can check, I'll check it :)
#11 muzsy
muzsy
  • 1 posts
Posted 23 August 2013 - 02:28 AM
I have the problem. I'm not sure if my brand new UX1 has to be exchanged or not. My input level is very low as described by CRXLunatic . I also have a PODxT which has a higher input level in POD Farm 2.5. I understand that the dry signal should be low to enable further amplification, effects, etc., but it is low enough to make me uncertain.
I hope it's working as designed, please let me know if you have any further information. Thanks!
#12 sidguitarrist
sidguitarrist
  • 7 posts
Posted 28 August 2013 - 03:36 PM
im having the same problem like  muzsy and CRXLunatic and this is driving me crazy,cuz my line 6 ux1 lacks of audio quality whem im making recordings.
