DT50 Loud Humming / Noisy
dt50 noise hum humming noise floor noisy
3 replies to this topic
#1 hatchback88
hatchback88
  • 2 posts
  • Registered Products:1
Posted 06 January 2016 - 02:28 PM
My DT50 212 has a prominent hum, even when no guitar is plugged in. It is not affected by the master volume level. It changes level slightly when using different voicings, but is quite loud in all of them. A tech listened to it and said that it is somewhat higher pitched than a 60 cycle hum.
It has always hummed and been noisy, but it was not such a problem in a band setting. Now I would like to use it more for recording and it has become quite a problem, as the noise floor is very high.
I have experimented with one or two different 12AX7 tubes in the past with not much difference that I could tell. I have not tried a Mesa SPAX7 as has been suggested in other posts.
I have opened a support ticket, but any help/guidance/info from the forum would be greatly appreciated. Thanks so much!
#2 hatchback88
hatchback88
  • 2 posts
Posted 09 January 2016 - 12:49 PM
Local tech just sent me home with the amp. Was beyond his expertise to troubleshoot or fix.
#3 Brazzy
Brazzy
    Power User
  • PipPipPipPip
  • 2329 posts
  • LocationU.S.A.
  • Registered Products:17
Posted 09 January 2016 - 06:46 PM
Check this out. When I had an issue with my DT50HD I contacted Line 6 about finding a place in my area for warranty repair and after trying 3 places that had been reccommended, 1 of them had closed, so I called Line 6 again and spoke to someone else. They told me no on would be able to fix it in my area and that I should send it to them. Which I did and they fixed it. I had one of the early DT50HD's. Man when it works it kicks a$$!
Hope you get'er fixed soon.
PS: In the beginning of my amp issue, some crackling noise during a few sessions followed by no sound. I thought it was power tubes and/or a fuse. The fuses were good so I did the tube change with the recommended pre amp tubes, power tubes and biased them. It worked for a short time and then ended up intermittently going out with a fading volume drop.
  • 1
#4 mtreehugger
mtreehugger
    Iknowathingortwo
  • PipPip
  • 466 posts
  • Registered Products:4
Posted 10 January 2016 - 06:37 AM
I don't think your amp is broken.  Please allow me to share my experience:
I did not notice the noise when I bought my previously-owned DT50-112 because it was on the floor behind a desk in a large room (the seller met me at his work, which was an auto repair facility) and still had remaining warranty so I only wanted to make sure there were no obvious problems.  The amp was so unused that the next day it smelled plus made all that noise and I freaked out!  I brought it in for service, and I posted a hundred times in various threads here on the forum, searching for and sharing answers.  Ultimately I bought a DT25 head, which amazes me daily in my basement.  I'm hanging on to the DT50 for when I need more power, but may sell it some day if I find that I don't.  Maybe.  I'm predicting these DT's (especially the DT50 since it's no longer made) will be sought after and will command very high resale values in a few years.  We're the lucky ones to have them now.
Here's the thing:  Those DT50's are noisey beasts if you practice by yourself in a small room at low power.  The noise floor is fixed depending on which voice you select, which is unfortunate and probably why they don't make them any more (which is VERY unfortunate).  Turning up the volume makes absolutely no difference until you get to screaming loud, in which case the noise has long since become inaudible.  When I did take the DT50 and play with a band, I never even noticed the noise.  Not once, even between songs.  I forgot all about it, actually.  So what seems huge and horrible in my basement doesn't even exist under the conditions the amp was designed for.
If your goal is to play in a group, my advice is to ignore the noise when you practice because you won't hear it in a band.  There was a guy who said he played in a church band and had to switch to voice 1 or standby between songs, but I think that's rare.
Here's what helps:
1) voice 1.  Have you tried the soldano amps?  (they call it "solo" something or other)  there's clean, crunch, and overdrive models available, and you can get very nice hi gain tones in voice 1!!!!!  If you don't have a POD HD, get one, or you can use MIDI to download the update for your amp, then download DT edit to set one of the voices (doesn't matter 1-4 or which channel) to one of these louder solos.  Any amp using voice 1 will have minimum noise, but the solos seem to my ears to be the best high gain tones.
2) use 2 speakers.  You've already got this covered.  If you think your DT-212 is noisey, the 112 is actually a bit worse.
3) put a Mesa MBSPAX7 in the inverter slot.  It's a very clean tube, and for me it took just enough of the edge off that with 2 speakers I could forget about the noise (except in voice 3, which is the worst).
4) be sure to try low power mode if you haven't already.  Over time I found that I don't like it much, except in the case of the solo amps, which react very nicely with it in the DT50.  If you do use MIDI and DT Edit, LPM can be turned off or on via MIDI commands and, from what I hear, probably saved to a patch in the POD HD as well!  (if so, each patch would require a LPM setting as it won't automatically change states for you)
5) practice in a bigger room (if that's an option).
I hope this helps!
EDIT:
I wrote the above in response to your personal e-mail request, which did not state that you'd already played in a band and were concerned with recording.  When I later saw your post, I copied that response here.  Sorry for the TMI!  Have you tried the low-impedance direct out jack for recording?  (I have not, I just use my HD-500 direct to record.)  Otherwise voice 1 and the SPAX7 may be helpful.
  • 2
Also tagged with one or more of these keywords: dt50, noise, hum, humming, noise floor, noisy
