Mkii Button Problem
3 replies to this topic
#1 JaPPa
JaPPa
  • 14 posts
Posted 03 August 2013 - 05:27 AM
Hi guys,
I'm using the MKII shortboard with a Spider iv 75. Here is my problem .. the buttons 'STOMP' and 'REVERB' don't always go on/off when pushed. Is there a way to calibrate or et-up the buttons so they work all the time? Other buttons are working perfectly.
#2 fflbrgst
fflbrgst
    Guru
  • PipPipPipPipPip
  • 2575 posts
  • LocationNew England
  • Registered Products:3
Posted 05 August 2013 - 05:14 AM
Make sure you update your Shortboard firmware by plugging into your computer and using Spider Monkey to check for updates.
#3 JaPPa
JaPPa
  • 14 posts
Posted 08 August 2013 - 01:18 PM
Amp and shortboard are up-to-date.
#4 fblamauer
fblamauer
  • 19 posts
  • LocationToronto area, Canada
  • Registered Products:2
Posted 18 October 2013 - 09:34 AM
This is a known problem with the micro switch buttons that are soldered to the internal circuit board. The buttons wear out and need to be replaced on a fairly regular basis.
I submitted a fairly lengthy post with all details of how to do this but the post has expired. In summary, you need to open up the Short Board and de-solder the failed switch from the circuit board, then solder in a new one. The switches are very cheap and can be sourced online or from any electronics supplier.
Next time I open mine up I will take pictures and re-post the instructions since this seems to be a fairly common problem.
This was the post in case anyone from Line 6 is paying attention http://line6.com/sup...e/366052#366052 but as I said, it is no longer there.
