brue58ski Posted February 2, 2016 Share Posted February 2, 2016 I know the HD500's can't be fixed but what about coding HD Edit program so it shows Hz & dB instead of percentages? Wouldn't that be a quick IF-THEN statement or whatever it is these days? I put a request in ideascale for this. Swing by and vote for this if you like the idea. Here's where you go.... http://line6.ideascale.com/a/dtd/No-more-EQ-in-percentage-in-HD-Edit/804275-23508?submitted=1 Quote Link to comment Share on other sites More sharing options...
kpsion Posted February 9, 2016 Share Posted February 9, 2016 Hi +1 % for equing is just ...... nonsense I would add another idea : putting global EQ at the end of signal chain... is a nonsense too , why not putting it in mixer ? in the amp or after amps ? cause sending lollipop in a reverb then eq after to correct is the bad way. I would add another idea :) : consistent default parameter for Amps, by default it almost sound bad and big volume differences exists....... And last one, maybe less variations of cabs, but better quality ones, cause same without tweaking , EQing, it amost sound bad Quote Link to comment Share on other sites More sharing options...
