DT25 Head - Replacing tubes
jegarcia
Hi guys.
How difficult is it to do this?. I just bought one of these units and I live in a country where there is no one that provides this kind of service. Shipping the head to the US for service would be extremely expensive both ways. I'm thinking that I should have bought something else.
Your comments would be most welcomed
JG
its no harder than any other tube amp.  BUT you must replace with the same brand and type of tubes (EH EL84 matched set).  Do not substitute JJ's or any other brand.
If you don't know what you are doing find a professional repair shop.  There are voltages in there that can kill you even when it is unplugged!  Any amp repair shop can change tubes and bias for you.  Here are the instructions for biasing both DT50 and DT25.
http://share.myflare.com/rtwSHH
  • Upvote 2
If there are no guitar shops then a qualified electrician might help. Or someone used to dealing with old radios.
I did it with a friend of mine after we watched a load of YouTube vids. You will need a voltage tester that is well insulated.
If you don't know about these things it is not worth your life to play with it though!
@ radatats
Thanks man. Very helpful post. After I posted I made a few calls and it turns out there is an authorized L6 dealer here.  They don't sell L6 amps but a tech there did say that if I bring the tubes (I went ahead an order a spare set of EH tubes) and the bias specs (which you provided) they can do the setup.
Feeling much better...
JG
  • 1 month later...
@radatats why is it so important to maintain same brand of tubes and not change? Have nothing against EH tubes, but just bought myself a DT25 and not sure how many hours on existing original tubes.
Have a brand new set of matched JJ's sitting in my parts box and wouldn't mind using them if possible to save a purchase. Especially as I sold the amp I bought them for.
Honestly never heard of having to use a specific brand of tubes with am amp. Is there a biasing problem or something?
Thanks
Tom
Thanks
Tom
There are some threads on this forum about people, including me, who replaced the stock tubes with other brands (JJ's in my case) and shortly thereafter ran into serious problems.  I learned my lesson and will only use the recommended tubes.
@Just Startin'
The amp was designed with the recommended tubes and L6 only tests with their recommended tubes. While you may be able to get away with other tubes it is best to go with the L6 recommended set. As Gear Head pointed out you could have unpredictable results not to mention that if your amp is fairly new you may void the warranty.
Best
Thanks
Tom
Yeah, somewhere back in the threads one of the technicians from Line6 got into the tube replacement conversation and explained that the amps were designed specifically to use EH tubes, and due to the nature of the power switching of the amp, other tubes present issues that can melt the circuit board, fry the amp, etc.
http://line6.com/support/topic/4713-replacement-tubes-recommendations/page-2?hl=tubes&do=findComment&comment=110463
http://line6.com/support/topic/13389-dt50-noise-floor-vs-dt25-noise-floor/?hl=tubes&do=findComment&comment=94862
http://line6.com/support/topic/15605-bias-dt-25-amp/?hl=tubes
  • 2 months later...
