Monitoring Through Pod Hd Is Way Too Loud.
daw pod hd monitoring volume loud
2 replies to this topic
#1 FenderBluesAAA
FenderBluesAAA
  • 11 posts
  • Registered Products:1
Posted 04 August 2013 - 05:48 PM
I'm using a POD HD500X and I am trying to record but the monitoring is way too loud. If I put a backing track in Cubase, the playback of that track is extremely loud and I can't hear anything I play. I have the master on my POD all the way up but if I turn down the master and turn up the volume, the tone changes. Is there anyway to not monitor what is in my DAW through the POD?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9226 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 04 August 2013 - 05:53 PM
You should be able to lower the volume of the backing track in Cubase. That's probably the easiest way to go about it.
#3 cabir
cabir
  • 86 posts
Posted 04 August 2013 - 08:18 PM
what phil_m said is obviously the easiest thing to do. the backing track might've been mastered or atleast compressed/maximised, hence the loudness.
don't know if things in the 500x have changed at such a fundamental level, but the volume knob in the amp parameters is purely the volume and does not affect tone. the master volume which affects tone is in the bottom settings of amp parameters.
the knob which says "master" is the master output of the pod. this is the master volume of the unit, and if this is turned up all the way, no wonder the music is LOUD.
if you don't get enough volume from the amp volume knob at the max. position, then the mixer icon after the amp on the pod has 12db of gain on both left and right channels. if you still want more volume on your guitar sound, pan both the channels in the mixer to the center. this is a lot of volume to give into the hands of one man.
hope this helps.
Also tagged with one or more of these keywords: daw, pod hd, monitoring, volume, loud
