Input Gain And Mic Recording On Tonport Gx
mic toneport gx gain
7 replies to this topic
#1 amireldor
amireldor
  • 6 posts
  • Registered Products:1
Posted 05 August 2013 - 02:13 AM
Hello,
I own an old Toneport GX (with the red color) and POD Farm 2. I haven't tried yet as I did not solder the right cable but, will I have proper input levels when connecting a dynamic mic? There's no gain button on the GX and no visible input gain button in POD Farm :( .
#2 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
  • Registered Products:6
Posted 06 August 2013 - 06:12 AM
Results may vary.
You would be better suited with a UX1 or UX2 as they have mic inputs.
Or you could use a mic-preamp.
#3 amireldor
amireldor
  • 6 posts
Posted 06 August 2013 - 11:34 AM
The GX input is an Insturment Hi-Z input, isn't it?
That is, the preamp's output won't match as it's usually line-level, or am I wrong?
#4 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 06 August 2013 - 12:27 PM
You are correct.
But I have seen a few users in the past report they could not get desirable input levels with their mic and had success by adding a preamp.
Of course you would need to careful with output level of the preamp.
#5 Rockbuster101
Rockbuster101
  • 1 posts
Posted 17 August 2013 - 05:00 AM
Ok call me dumb, but I am very confused, I have been at this alll night and ever since I woke up, all I need to know is two things, do have to have an interface? and am I able to use the computer main input for 1/8 input cables to pplay POD farm? If able tobwhat port is it?
#6 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 17 August 2013 - 06:16 AM
how did you get pod farm? it typically comes with an interface... and if it came with an interface you need THAT interface....
if you bought pod farm separately, then you MAY be able to use your existing card... IF the manufacturer provided ASIO compliant drivers...
if not... you need an ASIO compliant sound card or interface....
ALSO of note...
you speakers must be connected to the same interface/soundcard as you are inputing into.
#7 amireldor
amireldor
  • 6 posts
Posted 17 August 2013 - 08:07 AM
I purchased got the GX and the POD Farm. Maybe the 'big brothers' of the GX (such as UX***) got the Gain control on their software POD Farm views.
Note to answerers: Rockbuster1 is not amireldor though we are both n00bs on the forums and have the same avatar :)
#8 Triryche
Triryche
    Uber Guru
  • Line 6 Expert
  • 7370 posts
Posted 19 August 2013 - 04:59 AM
@Rockbuster - You need your Line6 interface to run POD Farm unless you purchased a separate Hardware Independent POD Farm 2.5x License.
@admireldor - Do you have POD Farm1 or 2. The reason I ask is the older Red Toneports typically did not come with POD Farm 2, unless you paid for the upgrade or it is was registered for the first time after a certain cut off date (I think Oct 2009??). Either way, tin the mixer view in the rec sends there is a +18 dB boost button. There are now software mic gains in POD Farm even for the UX1 and UX2 (with the exception of the +18dB boost).
Also tagged with one or more of these keywords: mic, toneport, gx, gain
