Is there a way to copy a whole bank to another bank without using the editor?
Dylanguitar
Is there a way to copy a whole bank to another bank without using the editor? Sorry if this is an obvious question.
Dylan
Actually the easiest way to do it is the Helix App.
  • Just highlight the four presets you want to copy by using the Shift button.
  • Press the "Export" link, select the target folder, press "Select Folder". All of the presets should export to that folder.
  • Select the target location in the Helix app (make sure there are four new contiguous locations to copy to, you will be overwriting their contents)
  • Now do an "Import". When you browse to the location you exported to, highlight all four presets from the bank you exported. Complete the import.
  • You are done!
  1. Just highlight the four presets you want to copy
  2. "Export" them.
  3. Select the target location in the Helix app (make sure there are four new contiguous locations to copy to, you will be overwriting their contents)
  4. Now do an "Import".  When you browse to the location you exported to, highlight all four presets from the bank you exported. Complete the import.
  5. You are done!
Very Helpful, thank you.
Dylan
  2. "Export" them.
  5. You are done!
I actually tried this and it didn't work. If I hit "export" it gives me an option to save to my hard drive, as if I were saving a bundle.
If I choose to "copy" 8 presets, and then highlight 8 different presets and press "paste", it only transfers 1 of the presets.
Any ideas?
Dylan
Any ideas?
Dylan
I made the instructions a little more explicit. I don't know if that will help. Not sure what is causing you an issue with this. It works 100% of the time for me. One thing you may want to try is when you are doing the export and are prompted for the folder you are exporting to, do not double click it such that you end up in the folder. Simply click it once so that it shows up in the "Select Folder" dialog box.
