kenmasters Posted February 15, 2016 Share Posted February 15, 2016 I am thinking of getting a used variax 300. I have a HD500x and had some basic questions. I've read that the hd500x is not compatible with the older models, but I don't know what this means. - Can I still use the older workbench software on the desktop to make custom configs? - When I plug into the hd500x via the VDI connector, what would be different between a 300 vs a newer JTV ? - are the older models missing newer firmware that makes a significant difference to the quality of the tones? lag or other important updates? thanks, K Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted February 15, 2016 Share Posted February 15, 2016 The older Variax will work with the HD500x just fine but you can't run the old Workbench with the HD500x. You will have to use the dongle to work with Workbench. The other features work and you can select which type Variax you have when you set them up on the HD500x. Quote Link to comment Share on other sites More sharing options...
kenmasters Posted February 18, 2016 Author Share Posted February 18, 2016 Ok thanks... too bad the USB interface isn't cheap or easily purchased where I am located. Quote Link to comment Share on other sites More sharing options...
