so i bought a spider IV 75w and i need a hand
shudson89
1. so i bought a spider IV 75w and i need a hand with a footswitch.
I want to use the looper but i cant push the button and then record and make my loops fit,
so i figure i need a footswitch. can the regular line 6 2 button footswitch control the looper function, start and stop? or do i have to spend another hundred for the multi?
2. is there a way ti update the preloaded songs to other songs online somewhere perhaps?
ALso on a side note, ive been looking at a trio pedal. if i use it the sounds from the looper will be affected by the presets i assume?
No, you can't use the 2-button (up/down) footswitch to control the looper function, you need either an FBV MkII Express or Shortboard.  Same thing with saving patches to your computer (or downloading patches and loading them to the amp) using Spider Edit - need to have the USB connectivity from the FBV MkII.
Not sure I understand your question about the trio, but yes, any changes done to the settings in the amp will affect the looped sound as well.  It's a very limited looper that way.
