Dotted 8th Settings?
Best Answer phil_m , 06 August 2013 - 05:22 AM
On the delay that you have set to the dotted 1/8th, you'd want a relatively high mix and low feedback (I'm assuming you're after something like the classic Edge-like dotted eight sound). By relatively high for the mix, I mean around 55-60%. You essentially want the repeats almost the same volume as the dry signal. You don't want the repeats to hang along for long, though, so you probably don't want the feedback more than 30%. I like the digital delay with modulation for this delay.
For the quarter note delay, you'd want it almost the opposite - low mix and higher feedback. I'd say try the mix at 30% to start with. Than the feedback you can adjust to taste.
Go to the full post
7 replies to this topic
#1 Bushman2
Bushman2
  • 69 posts
  • LocationSeaside, Orygun
  • Registered Products:3
Posted 06 August 2013 - 04:27 AM
I know that one way to get this is using a 1/4 delay into a .1/8th delay, but can't find a good setting for feedback and mix for this...
Does anyone know good settings that work well???
Guitars:
Gibson Les Paul Custom / Ebony & Gold
Takamine G20 Acoustic
Effects:
HD 500
Helix
Seymour Duncan Twin Tube Classic
Visual Sound Jekyll & Hyde V2 (Red)
Visual Sound H2O
Ibanez Tubescreamer
BBE Sonic Maximizer
MXR Carbon Copy
Barber Tone Press
Boss RC-2
Crybaby Wah
Boss TU2
TC Electronic Polytune
ISP Decimator
Amps:
Fender Twin Reverb '65 RI
Fender Hot Rod Deluxe
Fender Blues Junior NOS
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9043 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 06 August 2013 - 05:22 AM   Best Answer
  • 2
#3 Bushman2
Bushman2
  • 69 posts
Posted 06 August 2013 - 05:35 AM
You Rock!
Thanks Phil....
Guitars:
Effects:
HD 500
Helix
Visual Sound H2O
Ibanez Tubescreamer
BBE Sonic Maximizer
MXR Carbon Copy
Barber Tone Press
Boss RC-2
Crybaby Wah
Boss TU2
ISP Decimator
Amps:
#4 paengcalma
paengcalma
  • 6 posts
Posted 27 September 2013 - 04:16 AM
Hi Phil, just a quick one. Can dotted 8th be configured in HD400?
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 15909 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 27 September 2013 - 04:22 AM
Not directly using Tap Tempo. You can set it manually using bpms and milliseconds by doing the math. For instance, consider setting an 1/8 note at 120 bpm. This defines a quarter-note (a 'beat') to be a half-second (500ms). So an eighth note at that tempo is 250ms. And a dotted eight would be 375ms (if I remember my theory correctly!)
Change to a different tempo and you need to recalculate.
.... John Lennon
#6 paengcalma
paengcalma
  • 6 posts
Posted 27 September 2013 - 07:52 AM
I see. I'll have to play with it to figure it out then. Btw, I saw a delay calculator online too. Must be the same concept with the one you mentioned.
Thanks, Silverhead. Really helpful as always!
#7 ftuller
ftuller
  • 39 posts
Posted 27 September 2013 - 06:09 PM
To get a galloping delay effect I use digital delay dotted 8th into analog echo quarter note right before the amp. I use feedback at 10 for both delays (for a single repeat), dotted 8th mix at 70 and quarter note mix at 50. Bass and treble at 50.
#8 mjsever
mjsever
  • 10 posts
Posted 23 April 2014 - 07:49 AM
The manual says you can select dotted eighth for the HD500x, but I can't seem to get it through knob twiddling.  Do I need to hook it up to the PC to get this?
