Hd500 Into Engl E840/50 Having To Use Fx Loop
hd500 engl fxloop poweramp
2 replies to this topic
#1 Morrowindsr8good
Morrowindsr8good
  • 6 posts
  • Registered Products:3
Posted 06 August 2013 - 05:12 AM
Right I have posted this before but to no avail so I'm going to try again.
Basically the only way I can get my POD to send a signal to my ENGL power amp is to go via the fx loop and stick a loop block at the end of the signal chain which is rather annoying as I like the use of the looping function.
I have sent it directly into a PA before via the 1/4" out without an issue but for some reason it is not working going into the ENGL so I have no clue what the problem is.
The output signal is set to power amp, 1/4" line out switch set to amp, guitar in set to normal.
My rough signal chain is (working) Guitar in>Vol pedal>Amp sim>Reverb etc>FX block>FX Send (out)>ENGL>Cab.
The way I want it to work is; Guitar in>Vol pedal>Amp sim>Reverb etc>1/4" out>ENGL>Cab.
Has anybody got any ideas? It's been months and I still can't find a solution.
#2 mrkphpps
mrkphpps
  • 45 posts
  • Registered Products:2
Posted 06 August 2013 - 12:37 PM
Hi Morrowind
Sorry you're having problems getting the Engl to work.
Have you tried the 1/4" out set to line rather than amp?  I think the amp setting is designed for going into the pre amp input of a guitar amp, and I have mine set to line when I play through the effects loop return of my peavy valve king, and it seems to work for me.
Good luck
Mark
#3 Morrowindsr8good
Morrowindsr8good
  • 6 posts
Posted 07 August 2013 - 05:54 AM
You sir! are a gent!
That's sorted it out, can't believe that was all it was, and I'm glad that is all it was.
Cheers
Lewis
Also tagged with one or more of these keywords: hd500, engl, fxloop, poweramp
