M9 Clarification(s)
4 replies to this topic
#1 MassholeSteve
MassholeSteve
  • 3 posts
  • LocationWorcester or Boston MA
Posted 07 August 2013 - 04:49 PM
Just need a few things clarified with the M9.
1) 6 scenes, 6 effects per scene? Each footswitch controls one scene? like one bank (in a sense)?
2) Do I actually need a separate expression pedal to control the volume settings? Or can I have it at a set volume increase, in the manner of a clean boost pedal?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9239 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 07 August 2013 - 06:06 PM
Actually, there's 24 scenes in 4 folders. You can access any of the six scenes within a folder by hitting the footswitch that scene is assigned to when you are in scene select view. To get to the other folders, you turn the model select knob while in scene select view. The scenes really are more like presets. Within in each scene you can have six effects, three of which you can use simultaneously.
You could set up an effect to be a clean boost. One of the EQs or compressors could work for that.
#3 MassholeSteve
MassholeSteve
  • 3 posts
Posted 08 August 2013 - 05:34 PM
Few last questions: I guess I meant was do I need the expression switch for the "volume pedal" model. I ideally just need a volume increase, so that's what I'd use if an expression is not needed.
On an rp500 I tried today, you can't really have a clean boost that increases the amp's volume since the highest the "heel down" setting gets is the level you'd have if the pedal was bypassed. Does any sort of clean boost actually boost the amp's volume if you have the M9 in the amp's fx loop?
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9239 posts
Posted 08 August 2013 - 06:16 PM
The volume effect on the M9 behaves the same way as the Digitech pedal. It won't give you a volume boost. It only cuts. But like I said, there are other ways to get a clean boost on the M9. Whether or not the boost actually boosts the volume of your amp while in the loop, I would think it should work.
#5 MassholeSteve
MassholeSteve
  • 3 posts
Posted 08 August 2013 - 07:17 PM
So let's say I select the boost comp model. If I set the EQ stuff flat and compression to zero, it would just provide a clean volume boost (assuming the boost is clean since the boost comp is based off an actual clean boost pedal).
