Importing Hd500 Presets To Hd500x
hd500x hd500
6 replies to this topic
#1 kcguitars
kcguitars
  • 5 posts
  • Registered Products:4
Posted 07 August 2013 - 07:52 PM
Does anyone know if it is possible to import HD500 presets/set list/bundles into the HD500X? The editor won't do it. . .thought there might be a trick or an update for it.
  • 1
#2 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 08 August 2013 - 03:58 AM
Yes it is possible. The easiest way is to drag/drop an HD500 preset file (*.h5e) into any preset slot in the HD500x Edit program. Then SEND SELECTED preset(s) into the HD500x device.
.... John Lennon
#3 K3NTaj2
K3NTaj2
  • 26 posts
  • LocationWest Des Moines Iowa
  • Registered Products:6
Posted 09 August 2013 - 09:29 PM
I've been using my favorite HD500 patches on the HD500x without any problem.  With the added DSP I've been able to make some additions to them. I like the new footswtches and lighting around them.
#4 argusvidicon
argusvidicon
  • 23 posts
  • Registered Products:3
Posted 17 August 2013 - 12:32 PM
I'm happy enough with my POD HD500 that soon I will get a second one.
It will be the new HD500x.  I will want to transfer presets(tones) between the two.
I understand DSP Limitation of the HD500 compared to the HD500X.
My question is will there be any issue having both edit software versions on the same computer, as well as drivers for both POD units?
#5 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16061 posts
Posted 17 August 2013 - 04:30 PM
No issue - you can have several different Pod HDxxx Edit programs installed, and even running, at the same time. Only one of them can communicate with a connected HD device, though. That one is determined by the device that is connected.
.... John Lennon
#6 proyass
proyass
  • 1 posts
Posted 24 October 2013 - 08:16 AM
Dear whom it may concern,
I bought pod hd500x yesterday as new one.
In the set lists in the manual, there are 'best of hd, fx heavy, song/style, dual tones' and the rest of 4 say user 1,2,3,4.
My product in the set lists shows
best of hd, fx heavy, song/style, bass/aco/voc
L6Link < > DT
Could you explain why it is different from the manual?
How can I change the set lists as indicated in the manual.
It would be really appreciated if you would get back to me as soon as possible.
Thank you in advance.
#7 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 9234 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 24 October 2013 - 08:25 AM
I believe the manual has some old information that pertained to a previous firmware version of the HD500. The setlists that came loaded on your HD500X are correct. You're not missing anything. If you want to use some of those setlists for your own patches, you can overwrite what's there and rename the setlists.
Also tagged with one or more of these keywords: hd500x, hd500
