jay_06 Posted March 12, 2016 Share Posted March 12, 2016 hi is there a way to tie two amplifi units together to work as one? if so whats the best way to do this? in other words one would be used as a second speaker Quote Link to comment Share on other sites More sharing options...
capdoogie Posted March 13, 2016 Share Posted March 13, 2016 I think you would need an a/b box to Send a Signal to both. But you would have to run one dry and the other with fx or you will get a weird latency problem between amps even with same exact preset. There also might be a cable splitter for controlling presets changes to both amps via your Mkii short board but this is all theory. Quote Link to comment Share on other sites More sharing options...
EwenBoyan Posted March 16, 2016 Share Posted March 16, 2016 Hi everyone. I am new here. I do not have much knowledge about the amplifiers but as i am from the technical background i would like to share what i know about the amplifiers. In the case to use the two amplifiers together, you should couple them using the suitable coupling method of amplifiers. If you can share the details of your amplifiers with its specifications then i can tell you how you can achieve this thing practically. multi-layer pcb Quote Link to comment Share on other sites More sharing options...
