Dual Amp foot switch help
Antman74
Hi all. I'm struggling with something so I hope someone here can help me.
I want a patch where I have 2 amps. One clean and then one heavy...simple enough. I can't seem to get the footswitch assignment correct whereby I want to hit a footswitch that em goes from clean to the crunch amp...and also turns off the clean amp?
you have to assign both amps to the same foot switch, turn one of them off MANUALLY with the ENTER button, and then the foot switch will toggle between them.
Also, when you turn an amp off, the CHANNEL VOLUME will turn into a BYPASS VOLUME, which you would want to turn down to completely mute that path
