GenevaView Posted August 9, 2013 Share Posted August 9, 2013 Did a google search the other day for the Jen Electronics wah (just wanted to get an idea of what that model was all about), followed a link to a post here at the line6 forums where someone mentioned there is a digitech whammy pedal model for the pod xt's. Is this true? I can't find it anywhere in the effects lists. I scrolled through them all. Also the guy said you had to hold the tap/tuner switch down and then turn the select knob or something to get to that model. ??? I can't find it or the post where I read it. Anyone know if this is true or not? The guy seemed like he knew what he was talking about and it was definitely there. I'm using a pod xt live btw. Thanks. Also, isn't there a way to do a custom effects save like you can do with amps?? I'm positive I read that somewhere some time ago but haven't been able to figure that one out either. That would be a huge help in creating new tones. Thanks again. Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted August 9, 2013 Share Posted August 9, 2013 The effect is called Bender. Here's a document I found on it which may help: http://line6.com/supportarchive/thread/23550 You need to have the latest flash memory firmware in your Pod to have the Bender option. Note that you may lose model packs if you update and you have a second-hand unit with them installed and the owner didn't 'gift' them to you. 1 Quote Link to comment Share on other sites More sharing options...
GenevaView Posted August 9, 2013 Author Share Posted August 9, 2013 Cool. Thank you very much! Anyone know how to do a custom FX setting save? Quote Link to comment Share on other sites More sharing options...
GenevaView Posted August 9, 2013 Author Share Posted August 9, 2013 Nope. I am the one and only owner. I do have the bender model since installing the v3 upgrade way back when, just never knew it was the whammy and never used it cuz it didnt sound very good. ha. suppose it wouldnt without the expression pedal. Thanks again. Quote Link to comment Share on other sites More sharing options...
