Gerald_Howard Posted March 23, 2016 Share Posted March 23, 2016 Hello: Building some cords - only want to cut the wires once, to connect my M13 to my Send & Return loop on my HD500X and I can't find anything that tells me for sure if the tip on the send is the left channel or right. Does anyone know for sure? Yes I can assume, or re-plug, but I'm the type that would like the correct info BEFORE I cut the wire and solder it to the plug. Thanks Quote Link to comment Share on other sites More sharing options...
Gerald_Howard Posted March 24, 2016 Author Share Posted March 24, 2016 Thank you hurghanico. I wasn't sure if there was a "standard" and whether Line 6 followed it or did it their way. I've seen so many times things that are different than the "standard". Thanks again. Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted April 11, 2016 Share Posted April 11, 2016 All you gotta do is make a cable TRS into two TS jacks, you will soon find which is L or R. Quote Link to comment Share on other sites More sharing options...
