blessed1 Posted March 28, 2016 Share Posted March 28, 2016 I'm running a patch with 2 amps, one acoustic amp and the other an orange amp. I have a pan pedal assign at the amp block to select the different amps. Is it possible to assign an acoustic guitar to the acoustic amp and electric guitar to the orange amp? or can I only assign 1 guitar per patch? I'm using JTV 69. I thought I saw that someone in the forum had assigned to guitars to one patch. Thanks for the help. L Quote Link to comment Share on other sites More sharing options...
jandrio Posted March 28, 2016 Share Posted March 28, 2016 1. set input1=variax mags, input2=variax.2. set the jtv mag selector switch + the tone knob as required3. select the preffered jtv acoustic model from the hd500 (do not select thru jtv knobs, cause you 'll change the abv mags settings).4. use the acoustic amp on path b (fed by variax acoustic model)5. use the orange amp on path a (fed by variax mags=electric)check out this demo patchhttp://line6.com/customtone/tone/409204/ 2 Quote Link to comment Share on other sites More sharing options...
