targa2 Posted August 11, 2013 Share Posted August 11, 2013 When hooked up to the onscreen editing software via usb I lose my analog out for monitoring / recording. What setting am I supposed to change to rectify this. Thanks Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted August 11, 2013 Share Posted August 11, 2013 What device are you referring to? Quote Link to comment Share on other sites More sharing options...
targa2 Posted August 12, 2013 Author Share Posted August 12, 2013 HD 500. Is that what you mean? Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted August 12, 2013 Share Posted August 12, 2013 Windows may have changed your sound palyback/recording device. Right-click the speaker icon in the toolbar on the lower right of the screen near the clock and select Playback Devices and see what is listed. You may need to change the default device. You may also need to do the same for Recording Devices. Quote Link to comment Share on other sites More sharing options...
targa2 Posted August 12, 2013 Author Share Posted August 12, 2013 I'm on a Mac. I'll see if I can figure that route out for Mac . Thanks Just so it's clear what I am struggling with. I am hooked up through the stereo outs of the Pod HD 500 to inputs in Cubase. I am also hooked up to the editing software via USB. Is the USB connection trying to access the audio of the Pod and how do I bypass that so it behaves as it does when I am not hooked up via usb. Thanks Quote Link to comment Share on other sites More sharing options...
Mr_Arkadin Posted August 13, 2013 Share Posted August 13, 2013 So you're not monitoring via the POD HD500 I take it? If you're monitoring via the computer then what is probably happening is that Cubase is selecting the POD ASIO driver. Go to the audio preferences in Cubase and check which driver you have selected for audio rec/playback and select the one for your audio card (if this is indeed how you are monitoring). Please note ASIO can only select one device for both rec/playback. Quote Link to comment Share on other sites More sharing options...
targa2 Posted August 13, 2013 Author Share Posted August 13, 2013 Ok . I'll try that. Thanks Quote Link to comment Share on other sites More sharing options...
