Hd500x Presets
Best Answer djspleen , 11 August 2013 - 02:38 PM
I believe they are the same presets, and the 500 patches do indeed work with the 500X.  When opening with the Edit software, just change it to view all files (*.*) OR change the file extension (which I've not yet done).
Go to the full post
18 replies to this topic
#1 Guitarzan
Guitarzan
    Iknowathingortwo
  • PipPip
  • 204 posts
Posted 11 August 2013 - 08:27 AM
Are the presets included with the 500X any better than the 500 presets? We know that was a weakness - anything change for the better? If so, are they compatible with the 500? I'm curious if you could just change the filename and they would be.
#2 djspleen
djspleen
  • 59 posts
  • LocationLancaster County, PA
  • Registered Products:3
Posted 11 August 2013 - 02:38 PM   Best Answer
#3 mralmostpopular
mralmostpopular
  • 33 posts
  • Registered Products:1
Posted 11 August 2013 - 03:10 PM
They are the same presets. I don't know that I would call them a weakness. A company like Line 6 can't possible make presets that would work for every guitar/venue. Any device you get is going to have a couple decent presets and a bunch of stuff you'd never use. The power of the device comes in making your own.
#4 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17698 posts
  • LocationClemmons, NC USA
  • Registered Products:16
Posted 11 August 2013 - 03:11 PM
he was talking about using 500x tones on a 500... the factory ones... are the same... however, 500x tones can exceed the capabilities of the 500 and won't always work.
#5 djspleen
djspleen
  • 59 posts
Posted 11 August 2013 - 06:21 PM
I was answering strictly from the pre-loaded patch standpoint.  A customized tone designed on a 500X in theory would work on a 500, but there is the 500 DSP limitation you mentioned....right.
#6 Guitarzan
Guitarzan
    Iknowathingortwo
  • PipPip
  • 204 posts
Posted 12 August 2013 - 05:00 AM
Yes, I was talking about factory presets. Always looking for great tones, so thought I would ask if there's anything new here, and there isn't apparently.
FYI, it's old news here that the HD500 factory presets are almost universally bad - the worst of any product previously made by Line6, but not looking for a debate. Just an accepted fact by most.
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17698 posts
Posted 12 August 2013 - 05:05 AM
I'm glad you are here to voice the opinion (err fact, according to you) of "most"
#8 Guitarzan
Guitarzan
    Iknowathingortwo
  • PipPip
  • 204 posts
Posted 12 August 2013 - 06:34 AM
Haha caught my lack of precision in posting, good for you!  Really meant that it's fact most who've commented on the boards with their opinion on HD500 presets feel this way...it's old news.
#9 argusvidicon
argusvidicon
  • 23 posts
Posted 17 August 2013 - 12:29 PM
I'm happy enough with my POD HD500 that soon I will get a second one.
It will be the new HD500x.  I will want to transfer presets(tones) between the two.
I understand DSP Limitation of the HD500 compared to the HD500X.
My question is will there be any issue having both edit software versions on the same computer, as well as drivers for both POD units?
#10 Robzebr
Robzebr
  • 92 posts
Posted 17 August 2013 - 12:51 PM
Yeah but would it have been a big deal to do the following....?
How many models are there... 30ish....   Take each model and make 5 patches for each..... totally pristine clean... light overdrive... distortion... clean with reverb... overdrive with reverb and delay... (something like that)
... Have somebody do it that was fluent in guitar.. and who also knew the software...
This way the new owner can hit the ground running... they could still experiment and make patches on their own... but at least they are much further on their way...
How many posts have you read that said that the newbie owner was ready to pack it in with the 500 because they couldn't dial in a tone... ?   I've read quite a few... If you give them good usable tones up front for each model... the enjoyment factor is immediate instead of the feelings of frustration...
A one page cheat sheet .. that started with ... WHat are are you plugging in to?  Then pick these settings.
Most of the posts from new owners are either about .. dialing in a tone... or setup configuration... which are very related.. If you have the output setting wrong.. then that can impact dialing in a good tone...
Had they done that... 50% of the posts on here... wouldn't be here...
#11 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17698 posts
Posted 17 August 2013 - 04:17 PM
no problem at all... i think i have EVERY version of edit on my PC.
#12 dx2ylhv1a
dx2ylhv1a
  • 12 posts
Posted 29 October 2013 - 11:25 AM
Where can I download them from?
Thanks
#13 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17698 posts
Posted 29 October 2013 - 11:28 AM
just install the latest firmware, and tell it not to preserve your presets and all will be installed to your device.
be sure and backup your presets first if you want to save them.
#14 Settlesdj
Settlesdj
  • 1 posts
Posted 27 February 2015 - 05:20 PM
How many presets are included with the HD500X?  Is it just the 64 or are there more under the other set lists?
#15 Digital_Igloo
Digital_Igloo
    Line 6 Staff
  • Product Management
  • PipPipPipPip
  • 1756 posts
  • LocationCalabasas, CA
Posted 27 February 2015 - 08:28 PM
8 setlists x 16 banks x 4 presets = 512 presets total, all overwriteable.
Senior Product Manager, Line 6
#16 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17698 posts
Posted 28 February 2015 - 05:29 AM
i believe he may have been referring to how many of those come with "usable" tones pre-loaded from the factory...
pretty sure that at least  3 or 4 setlists are filled up to get you started... which you can, as stated, overwrite if you wish....
8 setlists x 16 banks x 4 presets = 512 presets totals, all overwriteable.
#17 pianoguyy
pianoguyy
    Power User
  • PipPipPipPip
  • 1719 posts
  • Registered Products:2
Posted 28 February 2015 - 06:27 AM
5 of the 8 setlists come pre-programmed, but they are completely writable
although, of the 5:
one of them is a 'best of'
one is for acoustic, bass, and vocals,
one is for the variax
one is a 'song stylist'
The other is called Heavy.
Really, the originals suck (no offense to the team).
But they give some excellent ideas as to some of what can be accomplished with the device. And they only demonstrate a fraction of what can be accomplished with time and patience for experimentation and tweaking.
And it sure would be nice if I could use 500edit on my Android Phone or Android Tablet to manage my Pod when not at home.
Even if it needs to be a '500 Lite' version that only allows for the import and export of patches, and not a full-fledged working program.
Something needs done.
#18 rstocks1
rstocks1
  • 1 posts
Posted 30 November 2015 - 06:33 PM
No this does not work. I followed this and now only have all "New Tone" presets.
#19 pianoguyy
pianoguyy
    Power User
  • PipPipPipPip
  • 1719 posts
Posted 30 November 2015 - 09:50 PM
a dozen posts before this. which one are you referring to?
