Not Able To "connect" In Workbench
Best Answer McLenison , 14 August 2013 - 11:57 AM
1.  Are the lights green on both sides of the Variax USB interface?  It sounds like the USB sides is green and the Variax side is red.
2.  If the Variax side is red, try plugging a normal guitar cable into the 1/4" jack.  Workbenck will not see the Variax unless it is powered on.  The Variax is not powered on unless something is plugged into the 1/4" jack.
BTW, I tried mine while not connected to the internet and it works fine, AS LONG AS I HAVE SOMETHING PLUGGED INTO THE 1/4" JACK!!
Thanks!  Everything was hooked up correctly, but I'm not sure what side the red light was on.  I'll try again this weekend.
Go to the full post
13 replies to this topic
#1 McLenison
McLenison
  • 99 posts
  • Registered Products:2
Posted 11 August 2013 - 01:03 PM
I've got everything plugged in and I'm not able to connect (battery = 2 lights) and I'm getting a bad connect message and red light on the box.  Computer was not connected to the internet.  Does that matter?
#2 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
  • LocationWashington, DC
  • Registered Products:21
Posted 11 August 2013 - 01:28 PM
Is the guitar powered on?  You might try plugging something into the 1/4" jack.
#3 McLenison
McLenison
  • 99 posts
Posted 11 August 2013 - 01:55 PM
Yeah, everything is plugged in, I just don't have internet connectivity at the workstation.
#4 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 11 August 2013 - 02:54 PM
USB issue perhaps?  Have you tried different ports?  Do not use USB 3.0 ports either.
#5 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 11 August 2013 - 03:10 PM
probably obvious... but the volume needs to be turned up... the electronics turn off if its dialed all the way down...
#6 McLenison
McLenison
  • 99 posts
Posted 11 August 2013 - 03:28 PM
It worked before with the same USB port.  Volume was up.  Shouldn't it still work without internet access?
#7 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 11 August 2013 - 03:57 PM
should still work without internet access, but i have seen changing ports help, since it reinitializes a new instance of the driver.
#8 McLenison
McLenison
  • 99 posts
Posted 11 August 2013 - 04:09 PM
How do you change ports?
#9 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17847 posts
Posted 11 August 2013 - 04:11 PM
plug the usb cable into a different port on your computer, sorry if it sounded like i meant something else.
#10 BigChas52
BigChas52
    Guru
  • PipPipPipPipPip
  • 2889 posts
Posted 12 August 2013 - 09:36 AM
#11 McLenison
McLenison
  • 99 posts
Posted 14 August 2013 - 11:57 AM   Best Answer
#12 soundog
soundog
    Iknowathingortwo
  • PipPip
  • 492 posts
Posted 12 November 2013 - 03:15 PM
The USB interface is unreliable and very finicky. I've had to futz with mine endlessly with a myriad of ethernet cables, standing on my head, rebooting, unplugging and plugging. Sometimes the magic green light is on and it still won't recognize my Variax. A piece of work....
#13 njc235
njc235
  • 29 posts
  • Registered Products:5
Posted 13 November 2013 - 12:51 PM
Plugged everything in, two green lights firmware upgrade to 2.0 failed but is now showing 2.0 in Monkey but Brand New JTV won't switch on.  This process is looking flakier than a cadburys flake!
#14 silverhead
silverhead
    Uber Guru
  • Line 6 Expert
  • 16062 posts
  • LocationOntario, Canada
  • Registered Products:16
Posted 13 November 2013 - 01:02 PM
Check that your JTV battery is well charged, and that you have a plug in the 1/4" jack (that's the power switch).
.... John Lennon
