Old-Rocker Posted April 6, 2016 Share Posted April 6, 2016 Hi,i'm back to 2 using amps,i've been using the HD left output into Combo front of a single amp. I now have a second Amp which has a send/return section,any suggestions on the best way to Cable,to use both amps? Thanks. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted April 6, 2016 Share Posted April 6, 2016 I'm assuming you're happy with the sound of the Combo amp and don't want to mess with that. Do you want the same HD FX on both amps? Do you want to use the preamp of the 2nd amp? The answer to these questions will help guide our recommendations. Quote Link to comment Share on other sites More sharing options...
bartnettle1 Posted April 10, 2016 Share Posted April 10, 2016 The FX out on the POD is a TRS This means you can divide the TRS into two TS outs one for each amp. You could also easily solder to get more length than what is commercially available The returns are L R on the POD so no need there. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted April 10, 2016 Share Posted April 10, 2016 It's going to be difficult to use one amp as a combo and the other using FX returns. You're best bet is to use them both the same way or use just one. Quote Link to comment Share on other sites More sharing options...
jeremybnz Posted April 12, 2016 Share Posted April 12, 2016 What you need to do is use the left 1/4" out for the combo amp, and the right 1/4" out for the other amp, create a amp setup with no amp on one side and pan that hard left in the mixer, set up the second amp with a preamp model and pan that hard right at the mixer, job done! Quote Link to comment Share on other sites More sharing options...
Old-Rocker Posted April 12, 2016 Author Share Posted April 12, 2016 Thanks,guys.I'll digest the info & start plugging in,i didn't reply to pfsmiths post,because i'm not really clear what i'm trying to achieve,i'm turning out to be useless in getting to grips with MFX pedals,this is my second attempt with a major brand & i just get lost,but on the bright side,i'm still alive & gigging. :) Quote Link to comment Share on other sites More sharing options...
