Pod Hd500 Patch Change Issue
pod hd hd 500 patches switch banks
5 replies to this topic
#1 recyclebin32
recyclebin32
  • 3 posts
Posted 12 August 2013 - 09:29 AM
I have 5 banks filled with patches which used to work perfectly fine. Now all four patches of the first bank work fine, but when I change bank, like to the second one, there is no sound from any patch, even in the third bank, only the third patch of the 3rd bank has sound, and only the second and third patches of the the fourth bank has sound, this is a really weird problem, I have never faced this before.
But when I connect the unit through POD HD Edit software and double press any patch from any bank, there is perfect sound.
I have tried reinstalling firmware, but nothing has helped.
Please help?
#2 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8239 posts
  • LocationMinneapolis, MN
  • Registered Products:2
Posted 12 August 2013 - 09:41 AM
After you've reinstalled the firmware have you done the global settings reset? Could be it... The other thing is that it may be that those patches got corrupted somehow. That's not unheard of.
#3 recyclebin32
recyclebin32
  • 3 posts
Posted 12 August 2013 - 10:05 AM
Global setting reset?
I pressed no when it said "Do you want to save the existing patches"
I've installed the patches again and it is still giving the same issue, its giving the same issue even with the factory setlist.
What should I do?
#4 phil_m
phil_m
    Uber Guru
  • Line 6 Expert
  • 8239 posts
Posted 12 August 2013 - 10:10 AM
I would try re-installing the firmware and doing the global settings reset. The instructions are here: http://line6.com/support/docs/DOC-2222
#5 recyclebin32
recyclebin32
  • 3 posts
Posted 12 August 2013 - 10:35 AM
I've tried doing this, the problem is still there, plus my unit hangs when I do the global resetting. "Update Flash" Nothing comes after that, the flash is the latest version!
This is really annoying. :(
#6 panaman
panaman
    Iknowathingortwo
  • PipPip
  • 131 posts
  • Registered Products:1
Posted 13 August 2013 - 11:19 AM
i have had the same thing since the latest update.
many patches, maybe 25%,  are mute. (edit/usb not connected).
i found if i go to tuner and back to the patch, the sound returns.
not a particular elegant workaround, but nothing else helped so far.
i also get the impression the sound is not like it used to be, even though not dramatically bad.
Also tagged with one or more of these keywords: pod hd, hd 500, patches, switch, banks
