frankiman Posted August 12, 2013 Share Posted August 12, 2013 Hi there, Just upgraded to a HD500X. One thing that is alarming me is not being able to figure out (dont know if it is possible) to have 2 independent tones in one single FS and then have the ability to control them by rocking the exp pedal back (for one tone) and then move up (for the other tone). This used to be great about the Pod X3 allowing you to morph your sounds from a clean tone with amp X to a dirty tone with amp Y. I have been able to pan with the exp pedal but this is useless as I want to keep both tones in stereo when moving my exp pedal. Any help figuring this out would be appreciated. Thank you Frank Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 12, 2013 Share Posted August 12, 2013 You can still do it, but setting it up would be a little different. You need to assign the channel volume parameter in both of you amp blocks to be controlled by the expression pedal. You would just have them set opposite one another. So when one volume is at 100%, the other would be 0% and vice versa. As long as you have the pan in the mixer block set to center for each tone, you can keep the tone stereo as well. 1 Quote Link to comment Share on other sites More sharing options...
frankiman Posted August 12, 2013 Author Share Posted August 12, 2013 you are the man, thanks! I was able to do it You can still do it, but setting it up would be a little different. You need to assign the channel volume parameter in both of you amp blocks to be controlled by the expression pedal. You would just have them set opposite one another. So when one volume is at 100%, the other would be 0% and vice versa. As long as you have the pan in the mixer block set to center for each tone, you can keep the tone stereo as well. Quote Link to comment Share on other sites More sharing options...
Crusty_Old_Rocker Posted August 15, 2013 Share Posted August 15, 2013 What's really cool is that if you use a JTV guitar you can fade between a modelled acoustic guitar through one FX path and the electric (magnetic pickups) through the other path. I have a Lola patch that I move from clean dobro to overdriven electric (Vox AC30 amp model) via the expression pedal. Cheers, Crusty Quote Link to comment Share on other sites More sharing options...
Crusty_Old_Rocker Posted August 15, 2013 Share Posted August 15, 2013 Oh, I have a similar patch for Stairway To Heaven that moves from 12 string acoustic to heavy (Marshall JCM800) electric. The pedal blends from 100% 12 string to 100% heavy electric. Cheers, Crusty Quote Link to comment Share on other sites More sharing options...
