Pod Hd Pro Not Working After Using A Digitech Footswitch!
pod hd pro digitech control 2 not working doesnt start up pod hd pro digitech control 2 not working doesnt start up
13 replies to this topic
#1 nimanecro
nimanecro
  • 7 posts
Posted 30 April 2013 - 08:22 AM
PLEASE HELP!!
everything was right before i connect a Digitech footswitch (Control 2) to my Pod HD Pro !!!!
now it doesn't work and when i turn it on, nothing happen. i'v tried to connect via USB but it seems dead :unsure:
is there any trick to start it again? :(
#2 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
  • LocationClemmons, NC USA
  • Registered Products:18
Posted 30 April 2013 - 08:31 AM
you can try holding down the left direction when powering on.
  • -1
#3 nimanecro
nimanecro
  • 7 posts
Posted 30 April 2013 - 08:42 AM
i've tried, doesn't work :(
#4 nimanecro
nimanecro
  • 7 posts
Posted 30 April 2013 - 09:53 PM
has POD HD Pro any internal fuse to cut the electricity?
if yes, how could i check it to replace?
#5 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
  • Registered Products:7
Posted 01 May 2013 - 08:55 AM
Good idea. I guess you'll have to open it. Once you locate the fuse, you'll probably be able to easily tell if the thin wire is broken.
Let's hope it's the fuse...
#6 DeanDinosaur
DeanDinosaur
    Gear Head
  • PipPipPip
  • 757 posts
Posted 01 May 2013 - 09:49 AM
Doesn't the HD Pro have a on - off switch? If that's the case then It probably does have a fuse.
  • 1
#7 nimanecro
nimanecro
  • 7 posts
Posted 01 May 2013 - 10:52 AM
yes it has, but there's not any box to change it from outside!
#8 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 01 May 2013 - 03:55 PM
does the pro use the same p.s as the rest of the hd line or is it integral
I'M SO HAPPY!
#9 TheRealZap
TheRealZap
    Uber Guru
  • Line 6 Expert
  • 17846 posts
Posted 01 May 2013 - 04:33 PM
it's internal.
#10 Inerzia
Inerzia
    Iknowathingortwo
  • PipPip
  • 369 posts
  • LocationSpain
Posted 01 May 2013 - 05:56 PM
Aren't fuses usually a part of the power supply?
#11 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 02 May 2013 - 11:55 AM
http://www.sweetwate...CFcIv4AodcUMAFQ
if this is the gear you used, it supply's power to the modeler. so maybe you supplied power to something that doesn't want power
I'M SO HAPPY!
#12 nimanecro
nimanecro
  • 7 posts
Posted 04 May 2013 - 09:48 AM
but Control 2 has not supply power, just working with a passive Ethernet cable.
  • 1
#13 toneman2121
toneman2121
    Guru
  • PipPipPipPipPip
  • 2788 posts
  • Locationphilly
Posted 04 May 2013 - 10:26 AM
The control 2 requires no setup and simply connects to the DigiTech GSP1101 via a single cable that supplies both power and control signals, making stage setup quick and easy.
sorry man, i read it wrong
  • 1
I'M SO HAPPY!
#14 rockzone
rockzone
  • 1 posts
Posted 07 August 2013 - 08:58 PM
hi, let me explain you something.
Every brand uses some types of connectors that commonly we can found in more than one device, for this case, the FBV socket on the POD HD Pro, this is the same connector in other brands like Digitech and other brands, this is to reduce production costs, easy connection and final user's simplification.
Line6 uses standard ethernet cables  (NOT CROSSOVER) to connect other line 6 hardware, like POD'S, FOOT CONTROLERS, VARIAX GUITARS. but you cant connect a variax in the fbv socket. the same for line6 Link, it uses a standard XLR cable.
It doesn't mean that the same connector uses the same communication protocol, thats because you shouldn't mix brand devices that were not designed to work together, instead you read info before you do that and check the products will work and wont cause a hardware or software failure.
In case of FBV port, i have read something about the signals used to control te POD's, I mean it uses a I2C protocol which is a kind of synchronous link, with a data, clock and power lines, this is totally different from a ethernet port in the computer, by example.
For this reason, you probably broke the POD if the connections between line6 and Digitech are not the same.
Ina better way, you can use MIDI interfases and controlers, which were designed to interact with a lot of products with the same type of cable and the same type of data signals, in this case you can mix any controler capable to send and receive MIDI signals without problems.
I hope you found the problem and the POD is alive.
PD. Im a electronic Engineer, i love music, electronics and this kind of product information.
Chrisrock.
Also tagged with one or more of these keywords: pod hd pro, digitech, control 2, not working, doesnt start up, pod hd pro, digitech, control 2, not working, doesnt start up
