littlebrain Posted April 16, 2016 Share Posted April 16, 2016 I recently set up my pedal train and wanted to include my line6 m5 pedals with my single pedals. For some reason i couldnt set up my line6 m5 with other pedals. I got the other pedals working separately so i guess im having confusion in patching the cables to the right port in m5 pedal. From the IN of the single pedal, where does patch connect to in the m5 pedal,I should mention i'm going to be using the Power All Godlyke adaptor to power my rig can't wait to set my rig up, if i can get past this Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 16, 2016 Share Posted April 16, 2016 The M5 has stereo inputs and outputs. In each case one of them is labeled Mono. That's the input/output you should use if the M5 is being connected in series with other pedals. Quote Link to comment Share on other sites More sharing options...
littlebrain Posted April 25, 2016 Author Share Posted April 25, 2016 Ive managed to get my m5 pedals set up with the other pedals, something has come up. I'm using the Godlyke power all adaptor, the m5 pedal LED panel lights up but it cant seem to work as you dont' see the icons and settings. It happens sometimes, i'm not sure but when the pin is placed in a certain way then it works, not sure is going on. Any suggestions on what could be wrong Quote Link to comment Share on other sites More sharing options...
moff Posted August 31, 2016 Share Posted August 31, 2016 The Godlyke Powerall will power the older Line 6 stomp modellers - MM4, DL4, etc, but won't power the M5/9/13. They need 9v AC, 1000mA, the Powerall is 9v DC. Maybe it's just the words you chose, but your description of your cabling made me have to comment. The IN of the single pedal shouldn't attach anywhere to the M5. Signal flows from your guitar, through your pedals, to your amp, so the signal chain should go: guitar -> IN pedal 1, OUT pedal 1 -> IN pedal 2, OUT pedal 2 -> IN pedal 3, etc. The OUTput of the pedal before the M5 should be plugged into the INput (mono/L) of the M5, OUTput (L/mono) of the M5 should go to the INput of the next pedal or to your amp. Quote Link to comment Share on other sites More sharing options...
c00lkatz Posted September 15, 2016 Share Posted September 15, 2016 The Godlyke Powerall will power the older Line 6 stomp modellers - MM4, DL4, etc, but won't power the M5/9/13. They need 9v AC, 1000mA, the Powerall is 9v DC. The M5 operates off of 9VDC. The included adapter is rated 9VDC @ 500mA, but I am successfully operating it off of a Voodoo Lab Pedal Power 2+ 250mA port. Quote Link to comment Share on other sites More sharing options...
