ChavaHerrera Posted April 16, 2016 Share Posted April 16, 2016 :D Greetings from mexico excuse the translation by google. I share in solution in groin and Spanish. Saludos desde mexico disculpen la traduccion por parte de google. comparto solucion en en ingle y español. ENGLISH I found the solution for error "DPS boot failed" generated after a failed upgrade of Line 6 HD 300 not know for 400 or 500, all this work to me, but not blamed me for permanent damage that could ever happen,That said we continue with the solution: the POD highly recommend not skip any steps1 uninstall the line 6 Most recent monkey and install 1.62- enter control panel / power management / USB / disable3- if you have USB 3.0 port Use it4- software in the following section seeks line6.comHD300, flash memory and choose the latest, you have to download the file and install it manually5- turn on your POD, already connected to the PC and the monkey executed, put hd 300 in restoration mode factory presets without giving continue (press. Fx3 and connect, this will enter that way) this will make your pc again to recognize the device.6- in the Line 6 Monkey click on the "Install from file" and give it to you downloaded earlier and now only have to wait about 10 min File writing 7- enjoy your new Line 6 HD 300 updatedNote: factory presets appear no longer be functional but to recover just turn off your HD300, press FX 3, connect it and restore it to factory, flash memory update will continue and recover the factory patches ESPAÑOL Encontre la solución para el error " DPS boot failed" generado tras un error de actualización de la line 6 HD 300 desconozco para la 400 o 500, todo esto me funcionó a mi , más no me responsabilizó por daños permanentes que podrÃan llegar a suceder, dicho esto sigamos con la solución : al POD recomiendo ampliamente no omitir ningún paso 1 desinstalar el line 6 monkey más reciente e instalar el 1,6 2- entrar a panel de control/administrador de energÃa /USB / deshabilitar 3- si cuentas con puerto USB 3.0 usalo 4- en el apartado software de line6.com busca lo siguiente Hd300 , flash memory y escoge la más reciente, hay que bajar el archivo e instalarlo manualmente 5- enciende tu POD, ya conectado al pc y con el monkey ejecutado , poner hd 300 en modo restauración de presets de fábrica sin darle continuar( presionar. Fx3 y conectar , esto hará que entre a ese modo ) esto hará que tu pc vuelva a reconocer el dispositivo . 6- en el line 6 monkey clickear en el apartado " instalar desde archivo" y le das al que bajaste anteriormente y ahora solo tendremos que esperar cerca de 10 min de escritura del archivo 7- disfruta de nuevo tu line 6 hd 300 actualizado Nota: aparecerá sin presets de fábrica pero ya será funcional , para recuperarlos sólo apaga tu hd300 , presiona FX 3, conectala y restaurala de fábrica , la actualización de memoria flash se mantendrá y recuperarás los parches de fábrica Quote Link to comment Share on other sites More sharing options...
