Reaper/Windows Question
reaper windows output speaker mac pc
5 replies to this topic
#1 jel476
jel476
  • 4 posts
  • Registered Products:1
Posted 20 April 2016 - 08:12 PM
I've been using Reaper for years on a Mac without much of a problem. However, recently I switched over to a PC and I'm having trouble getting my POD HD500x's output to come through the computer built in output. It was very easy on a Mac, but I'm having trouble making it happen on WIndows 10. I don't want the audio to output to the POD, I want to hear it through the speakers.
#2 rmp5s1
rmp5s1
  • 34 posts
Posted 20 April 2016 - 08:32 PM
Are you using the ASIO drivers?
#3 jel476
jel476
  • 4 posts
Posted 20 April 2016 - 08:53 PM
Yes I am. Should I be using something else?
#4 DunedinDragon
DunedinDragon
    Power User
  • PipPipPipPip
  • 1459 posts
  • LocationDunedin, FL
  • Registered Products:3
Posted 20 April 2016 - 11:22 PM
Most likely since the POD is being seen as your audio device it's being defaulted for both input and output.  You can change the default playback device through the control panel audio devices and select the computer audio device as your playback device.
#5 line-6-user
line-6-user
    Iknowathingortwo
  • PipPip
  • 238 posts
  • Registered Products:4
Posted 21 April 2016 - 05:24 AM
There is a setting within the pod ASIO driver in Reaper's Audio settings that will allow you to switch the HD500 Audio Monitor to OFF, which it will output only the processed reaper sound. Remember that you will be getting some audio latency though, the amount of latency is dependent to what hardware and software you are using.
I would have given you a step by step instructions but I am not near my computer.
Hope this helps you.
Here is my first attempt on creating a patch for "Another Brick On The Wall".
http://line6.com/cus...ne/tone/220305/
http://line6.com/cus...ne/tone/220306/
http://line6.com/cus...ne/tone/220304/
#6 jel476
jel476
  • 4 posts
Posted 23 April 2016 - 08:35 PM
Ok so I changed the playback to my speakers and I was able to make all the audio play through there... except for Reaper's. In other words, I can play itunes and hear it through my computers output but Reaper's recordings or monitoring does not play at all. Anybody know how to fix this? I never had this problem with my macbook.
Update: Ok so I went to audio setting>Recording>Line 6 pod>>listen Then I checked the "listen to this device" box, then I selected my speakers in the dropdown menu.
This allows me to monitor my playing through the computer. However there are 2 problems:
1. Terrible latency
2. I still can't hear something that has been recorded.
Any solutions?
Also tagged with one or more of these keywords: reaper, windows, output, speaker, mac, pc
